This saw project has been kicking around way too long. I finally got around to installing the saw nuts, filing teeth, and sharpening. It is filed 9 point (8 TPI) rip with ~0-2 degree rake. I relaxed the rake slightly at the toe the first couple of inches. The saw plate is .025" thick and 19" at the tooth line. The brass back is 0.156" thick and has a sawn groove.The saw plate and back are tapered to relieve some of the weight at the toe. It is aggressive cutting but starts nicely if you use a light touch.
Nice saw you made there! Very cool! Did you get the brass slotted back from Issac of Blackburn Tools, or did you make it yourself? How about the medallion? Did you make that or adapt something? Did you buy a metal lathe?
A mill would be nice but I am not sure I want to go down that road yet. Saw nuts are from Wenzloff, Adam helped with the back, and the handle is not copied from a particular maker.
the handle is inspired from early to mid 19th century saws. My desire was to have it sit closer and more inline to the tooth line. The weight of the saw provides all the down force needed.
I've got saws with hands down toward the middle and the more modern type (Both short and long), and the lower handle works fine with teeth filed to accommodate for it (just a little more aggressive).
My first backsaw kit was an english type with a heavy spine and a 16" plate with the handle down almost as low as yours and 10 points. Like you say, it's an adjustment to get it started, but it takes just a little bump, and anything it's too aggressive for is something I wouldn't saw with it, anyway.
Beyond the obvious need that the saw has to be taller than the tenon length, does the taller saw make aiming easier? In other words is a tall saw advantageous for any length tenon because it is easier to see/feel it is vertical?
Handsome looking handle. What is the saw plate? Spring steel or something else? Curious minds and all that.
Yeah, I also miss the dinners before the meetings. Good company, good projects to look and and tall tales to listen to. Maybe in September ... hope so.
The taller saw does not make aiming or keeping it vertical easier for me. The advantage for me is less teeth per inch and more length for faster cutting.
