Done traditionally this can be a trivial task. I wedge the drawer in position and rub the stop onto the back of the drawer. When the glue sets I add two brads in case the glue weakens in a 100 years of so.
This bedside dresser is for a young granddaughter. I thought this whimsical Chester County line and berry pattern would be suitable. Never seen a Chester County holly on cherry, but this example suggests it works. I did do a test pattern to avoid the risk of it not working. The drop pulls are Period but not Chester County Period. The place I bought them in Lancaster Co was not enthused about adding them to a Chester Co piece. I think they look at home on this piece if not Period Correct.
In your picture, is your drawer stop just laying there for the illustration, or have you already glued it in place in that skewed orientation? The times I have done them that way, I always tried to get the front face of the stop parallel to the back of the drawer front. I would be concerned if they were skewed, that in use the front corner would be crushed or it would put a ding in the back of the drawer front, causing the drawer to close too far. The more it was used, the worse it would get.
Due to a logistics problem (contractor headspace error) on one job we needed to install the cabinets before we had finished the drawers, and didn't have time on installation day to install the drawer bottoms in the drawers on site.
I designed adjustable cams that screwed to the back of the cabinet and stopped against the back of the drawer side. I scroll sawed several from some 1/4" baltic birch and drilled a countersunk hole in the middle of each one. I installed them in the shop. They could then be adjusted on site and fixed in place with a screw driver and a spot of glue (or a couple of brads).
Don't worry about the rectangle labeled "runner". I have no clue what I intended, but I drew this 20 years ago, so I'm not surprised.
The diagram shows one cam overlaid in both full forward and fully retracted positions.
(This method works even easier if you can get access to the back of the cabinet to adjust the cams). Having done them both ways, I highly recommend Bill's way whenever possible.
NB: When restoring an old chest of drawers, if a front mounted stop is lost, there is often enough glue left on the drawer blade that you can guess where to apply a new drawer stop. If you get it set too far forward, you can easily adjust it with a shoulder plane.
