nose bits
nose bits
justin ball
nose bits
justin ball
Anybody got experience or a link to a video about sharpening nose bits? Bit like a spoon bit, but it's got this tiny cutter. Any history on them? I touched one up and it went ok is soft wood, but I don't see it being a hot seller.
Re: nose bits
Re: nose bits
Charlie
Put loose grit abrasives (dry, paste, whatever you have) in a fairly shallow hole you started with the nose bit, add a few drops of oil if using dry abrasives, then drill the hole deeper. Do it several times.
Re: nose bits
justin ball
Re: nose bits
justin ball
Are you sure this works? Have you done this and consistently got good results? I mean, this sounds great and it would clean it up, but also sort of like it would blunt it....
Re: nose bits
Re: nose bits
David Weaver
I'm assuming that you're talking not about the shell type bit that looks like a thumbnail gouge (not quite, but sort of like that) , but rather the one that has a shag of metal bent in toward the center of the cut?
If the bit can be filed, you can just clean up the geometry on the outside if losing clearance bothers you.
Coulters on plows get the same kind of wear that charlie is advocating abrading onto the bit, and they just wear smaller and smaller but usually have a keen leading edge.
Re: nose bits
Re: nose bits
Charlie
It worked for me, made a noticeable difference. I've never owned a brand new one, so I can't compare it to that. This is an old 'trick' that's been around forever I'm sure. Can't remember where I first came upon it, but it was probably in an old Fine Woodworking magazine.
Re: nose bits
Re: nose bits
Charlie
Works on gimlets too...
Re: nose bits
justin ball
Re: nose bits
justin ball
Gimlets too? I got an evening's fun to look forward to. Now to find some metal polish, or valve lapping compound or something...I'll have to keep my camera with me...
Re: nose bits
Re: nose bits
Charlie
Auger bits as well to a point. Don't go crazy with any of this or use too coarse a grit or you'll lose the outside diameter/clearance the particular bit needs to work.
Re: nose bits
justin ball
Re: nose bits
justin ball
OK. I buy my auger bits 90% dead at car boot sales, and then use a set of small files to clean up. When I finally get fed up with them, I stick them in the bucket garden pots, screw end up. It stops the cats from crapping in the tomatoes. (Roofing slates split long ways and up ended like a ring of standing stones also works). One day I might buy a NEW one to see what I've been missing.
Re: nose bits
Fine woodworking email tip material...
David Weaver
...absolutely word for word. They'd never print it, but it's pure gold :) :
"I buy my auger bits 90% dead at car boot sales, and then use a set of small files to clean up. When I finally get fed up with them, I stick them in the bucket garden pots, screw end up. It stops the cats from crapping in the tomatoes."
