plane knob dimensions
Jack Guzman from Maine
I have an early stanley rabbet plane #10. It is only 12 5/8" long but is not a #10 1/4. If someone has one similar I need the dimensions of the front knob. Height,width at the large diameter,width at the base and width at the narrow part in between.
Re: plane knob dimensions
Wiley Horne
Hi Jack,
Interesting plane!
If no one has the right model, I can measure a Bedrock 605 (Tyoe 6, 1912-21). Has the tall knob on a raised casting. Also the short knob on a Bailey No. 3, pre-WWI, Type 11.
Does your plane have a raised casting for the knob, or does it sit flat on the bed?
Wiley
William Duffield
I have one out in the shop. If yours is a similar type to mine, which is pretty early, I'll get you the measurements. In the meantime, maybe an iPhone picture will help? I think Wiley's question on the cast ring is most pertinent. Are you looking for a high knob or a low knob?
I measured to the top of the brass nut with it backed up a couple turns and I got 1 7/8",so I guess I have my height. Not sure if you can see it in the poor photo but it has a raised portion for the screw. I have a knob that fits but it is too big in width and looks wrong. That is why I want the dimensions of a similar plane.
I have a #3 I could measure but I want to try to get the dimensions of a similar plane so I can turn a new one that is the proper size.
William Duffield
Mine is a #10 Type 7, built between 1893~1899. It is 12-3/4" long, which does not match any of the measurements in Walter. Leach, however, notes that the length was reduced to 13" in 1887. That's pretty close. It has the low knob. Stanley changed to the high knob in 1919 and cast the ring or receiver in the bed for the knob starting in 1929. As far as I know, the knob dimensions were the same during the same time period for all Stanley bench planes. The #1 might be different, of course, but the #10 and #10-1/2 should be the same as the #4 and #5.
So, you only have two choices. You need to decide whether you want a low knob or a high knob, and then get your dimensions off of any Stanley bench plane of the matching style and time period.
I seem to have a spare rosewood low knob in the shop, but I can't remember what it came from. Very curious.
Thanks William. I'll copy a #4.
