Anyone seen any of these lately?
Pat Riley
About a 15 years ago I bought about 20 sets of these.
I have finally run out, and I can't seem to find them any more.
The inserts are easy to get, the thumb screws seem to be extinct.
If you know where I can get something similar, I'd appreciate a heads up.
Thanks,
Pat
Re: Anyone seen any of these lately?
Wiley Horne
Pat,
David covered McMaster. Here is what a quick search of MSC Direct shows. I searched ‘knurled stud’:
https://www.mscdirect.com/browse/tn/Fasteners/Bolts-Screws-Cap-Screws/Screws/Thumb-Screws-Hand-Knobs?navid=12108793
You would need to find threaded inserts to match the thread pitch and depth of the stud.
Wiley
MSC—‘knurled thumb screw brass’
Wiley Horne
When you get there, look at the search block, and click on the search string that is teed up:
unless something has changed...
David Weaver
...MSC will probably be cheaper that mcmaster for almost everything.
I've had luck finding things like stainless knurled screws directly from china (on ebay) when I want just one of something that's $4 each or $40 for $25.
It may require buying the parts from separate sellers.
Eg, this item (or something similar) for the hardwood threaded insert:
383055416255 (that's an ebay item no)
or if you're looking for something like #10-24 knurled screw.
https://www.ebay.com/sch/i.html?_from=R40&_trksid=m570.l1313&_nkw=knurled+screw+10-24&_sacat=0&LH_TitleDesc=0&_osacat=0&_odkw=knurled+screw+10-2410-24
one other thing
Wiley Horne
It might not matter in a dry setting, but best practice would be to pair steel thumbscrew with steel insert, and brass with brass, to avoid battery effect of steel on brass.
Wiley
I hate when that happens...
Jim Matthews
...it's galling.
