Derek's Brass Dovetail Marker
Don Stephan
Visited your inspiring web site www.inthewoodshop.com looking for bowsaw plans (which I didn't find) but stopped by to read a couple times your article on making brass dovetail markers. My question, how accurately can the angles be measured, and how to measure them that accurately?
Thanks in advance.
Don Stephan
Re: Derek's Brass Dovetail Marker
Jack Guzman from Maine
https://toolsforworkingwood.com/store/more/bowsawdesign.html
The link is to Toolsforworkingwood's article on bowsaws.
William Duffield
Here is an archived copy of the original bowsaw plans by BugBear. Just about all modern bowsaws started here.
https://www.oocities.org/plybench/bowsaw.html
A hint: If you convert the dimensions from metric back to the original imperial units, they make a lot more sense.
Bowsaws
Jim Matthews
To the OP -
Drop me a line if your just looking for bowsaws to use.
I have several, just gathering dust.
Jim
Making the Brass Dovetail Marker *LINK*
Hi Don
You can see that I am using a sliding bevel in this picture ...
I made four angles choices: 1:5; 1:6; 1:7; 1:8
Each of these is a ratio, for example, 1” across and 7” down.
On a piece of paper/MDF/ply, scale off 8” in one inch increments along a verticle axis, and a single 1” mark along the horizontal.
Now use the sliding bevel to connect the 1” to whichever ratio you intend to make. That creates the angle you see in the photo.
article in question
Re: Making the Brass Dovetail Marker
Don Stephan
Thanks for the prompt reply DC. When I read a couple times the section of your article describing fussing with slightly wrong angles I assumed you were using some high tech digital scale, especially with such short edges.
Still wish we could find some wonderful down under expressions in your articles. Re-reading a PG Wodehouse story and smiling over the numerous examples of British slang, even if I don't understand most.
