Lignum Vitae plane
Lignum Vitae plane
Lignum Vitae plane
Glen Yoder
About 20 years ago I was at a meet where a guy was selling his deceased father's collection of wood. The guy was making blocks for kids to play with and he had cocbolo, ebony, and such in large chunks. The large chunks were $20 each. I bought a chunk of lignum vitae that was 3" x 3-1/2" x 24".
Our orders are down so this week we were only working 9 hour days instead of the usual 10. Thus I had an hour at the end of the day to use the shop. I decided to build a smoothing plane out of the lignum vitae. I had purchased a 2" iron and chipbreaker from Ron Hock previously for this purpose.
This was built entirely with power tools. I have about 4 hours into it at this point. The wood is an orange color when cut and turns to the dark brown rapidly. The side I photgraphed has a large sapwood streak in it but it is only about 1/4" deep. I need to flatten the sole yet and then grind and hone the iron. I made some shavings with it but it does not work well at this point. It was a fun project, weighs about 3 pounds, and I am very happy with the results.
Re: Lignum Vitae plane
Wiley Horne
Glen,
Very cool! That’s an amazing big chunk of lignum. Maybe you have enough left over for a mallet? Please let us know how the plane works as you refine it.
One thing you might do is check the fit of the wedge to the blade. You want the wedge slightly sprung, so that it is focusing pressure on the iron at two places—at the top of the bed and down near the cutting edge. This is easily done by lightly scraping the underside of the wedge—in the middle, only—until you can just see a sliver of daylight in the middle when you put a straightedge down its length.
Try the underside of the wedge with a straightedge—it may already be that way. You want the underside to have just a hair of concavity. If it’s convex under there, the plane won’t work right.
Wiley
Re: Mallet
Glen Yoder
I think that by carefully cutting out handles and heads out of what is left of the chunk of lignum I can get 2 or 3 mallets out of it. I like round mallets but I don't have a lathe. If I get a stimulus check I plan on buying a mini lathe and these mallets will be the first project.
Glen, this plane has loads of potential, but there is a potential issue which may need to be corrected. Is the bar for the wedge round or flat on one side?
The heart of Krenov's planes was not simply that they were laminated, but that the wedge was held by a shaped bar ...
This bar rotates so that the flat mates with the wedge.
The problem with a round bar, especially a metal one (harder than the wood), is that it will impress its mark on the wedge. The wedge will then not tighten.
The solution is to file one side of the bar flat, and ensure that the bar can rotate.
Article: http://www.inthewoodshop.com/ShopMadeTools/BuildingaKrenovSmoother.html
Easy fix
John in NM
Two actually.
Holes for the pin can be repurposed for a machine screw - smaller than the 1/4" (?) pin. Screw captures the flat sided cross bar and holds it in place. Trouble is it's a bit hard to set up, you need to make bushings to go in the holes, one countersunk for the screw head, the other threaded for the screw on the other side. Cross bar itself is relatively easy, drill the hole first then sneak up on the shape required by planing away material using the hole as your reference. Not so easy with power tools though, never found them good for sneaking up on anything, belt sander maybe.
Second fix would be to use the pin as is, and make a flat sided cross bar to go around it. Carefully drill 2-3 cross pin holes to keep the two together and install roll pins (small ones, anything under 1/8") once the cross bar is assembled in the plane. Probably best to get the roll pins started with a few light taps, then use a small C-clamp to press them in place.
Two more just occurred to me - super easy, file a flat on the brass pin. Won't need to be huge with a lignum wedge.
Or drill and tap the pin for tiny screws in a line where you want the flat to be, then screw on a flat piece of brass. That one is a bit harder to pull off, since you need to be able to drill and tap for screws and the pin needs to be loose enough already to rotate significantly once the flat piece is screwed on.
That is a nice plane Glen, keep after it :D
Re: Mallet
John in NM
Lignum is perfect for the heads, but I'd use something with more bending strength for the handles if they are to be used in earnest. Hickory is the easy one, as any old sledge or maul handle will provide the material. Or a new one from the hardware store would do, you can easily get three from a new sledge eye handle. I've busted more than my share of maul handles, I keep the broken ones for this kind of use.
White oak, beech, even maple probably good alternatives. Osage orange is overkill, but would be great if there is some available in your area and you have the time to dry it. I have to buy the stuff out here ($$$$) but it makes a fantastic ax handle.
Re: Mallet
I am curious why you - and anyone else - prefers a round-headed mallet?
In my opinion - respecting that this is a personal preference - round mallets introduce the risk of a glancing blow, which can be damaging.
A straight face, on the other hand, presents less risk. Plus it focusses the force and one might use a smaller, lighter mallet more effectively.
Re: With Mallet Aforethought
William Duffield
IMHO, it's a lot easier to learn to steer a round head mallet than a dovetail saw. It doesn't take a lot of practice to get proficient at centering the strike on the axis of the mallet. You don't even need to look at the mallet, like you do with a square head mallet.
With a round head mallet, there is only one way to set it down. If you make a mistake, you learn quickly that it will roll off the bench and hit you on the foot. With a square head mallet, there are an infinite number of ways to set it down, and you have to look at it to pick it up again and then rotate it in your hand to orient the face correctly to the object.
I disagree with your statement that a flat headed mallet focuses the force better than a round mallet. The amount of force transferred is dependent only on the mass of the mallet, its speed at impact and its elasticity. Of course, the elasticity of an end grain impact is different than a side grain impact, but that choice was not included in your argument. I have seen both square head and round head mallets with end grain, face grain, and edge grain striking faces.
We all know from playing baseball that a face grain strike is more likely to break the mallet head or handle than an edge grain strike, so a square head mallet could be more durable than a round head mallet if the latter is used with a random orientation. Maybe we need to brand the round head mallets like they do Louisville Sluggers?
A mallet with a square or rectangular cross section perpendicular to the grain is more likely to split than one with a round cross section.
A round mallet is quicker and easier to make (assuming you have a lathe and skew chisel). If you want a handle and head of different woods, then you will also need something to drill a hole in the head.
Do you ever play billiards? With a round head, you can apply english to your strike. :D
Re: Mallet
Glen Yoder
I may make the mallets square head, actually the face would be angled and the top and bottom curved. I have some of these and they are good mallets. I do not have a lathe right now so I would have to buy one to make round mallets.
A round mallet has the same striking face no matter how you turn it. Applying it directly to the chisel instead of a glancing blow is a simple matter of hand eye coordination. It is very easy to do instinctually. I just find it easier to hit a direct blow with a round mallet than a square one.
Re: Mallet - no lathe needed...
John Aniano in central NJ
Glen,
You said you couldn't make a round mallet because you lack a lathe. But, in reality, that is not really true! You could make a round mallet head by squaring up the tapered stock, sawing or planing octagonal facets, knocking off those corners to make a tapered 16-sided head, and then a 32-sided head and just kiss the corners off that and you will have a near fully round mallet head. Then a bit of sanding to wrap it up. I do this all the time in making the tapered stick of a musical instrument bow. They are planed from square through to a fully round cross section. Plus, it's a good exercise in layout and execution. And it's fun too! Then, just make a handle in the same manner and glue it into the head. If you are making lots of mallets, by all means, get a lathe, but if you might make one or two, you can make them without a lathe!
Plus, if you really wanted to get fancy, you could make an oval cross section mallet. Why you might want this, I don't know, but the method I've described above would allow you to make one. Offset turning in your currently nonexistent lathe would do it too, but for one or two examples, I'd go with my method.
Just my $0.02...
John
