OT - DE Razor shaving
Here’s a topic that David may find interesting. Others too, I hope.
I’ve shaved with a DE (double edge) razor for many years. Started with one, spent a decade or two with a twin blade Gillette Sensor (which is a nice razor - light and nimble), before returning to a DE razor a good number of decades ago now. My choice of absolute best, which I have used for many years now, is a Japanese Feather razor.
I have also used, and enjoy switching to on occasions, vintage DE razors, such as a Gillette SS (I have a classic 1942 model). Also more modern razors, such as by Merkur. Trying different razors is a hobby for some (not one of mine, though).
The blades I like best are also by Feather.
Now here is the interesting part: the reason I mention these DE razors is that they are all excellent. Mostly, a blade lasts me about 5-7 days with one of the alternatives. However, when I use the Feather razor, I get double the amount of shaving from one. In fact, I can take a blade from one of the other razors, when it is starting to feel gritty, place it in the Feather razor, and it transforms into a different - sharp - beast.
The Feather razor has an excellent reputation (they are quite expensive), but that does not explain the difference in blade longevity. Any thoughts?
Re: OT - DE Razor shaving
David Weaver
I know fairly little about DE razors (I have had a 1904 gillette or something of that sort - too primitive, and still have a gillette fat boy and superspeed - i use them once in a great while when traveling).
I've got a gaggle of feather razors, but they're the single-edged kamisori style (got them for a song). I'm embarrassed to admit I've never tried them.
Those blades are intentionally flimsy (all of them, all DE blades that I've seen - to work in different razor designs) and I would guess that the longevity in the feather DE razor (which I've never seen in person) is probably a testament to the razor itself holding the blade more firmly and not allowing it to slap and take hairs on for cutting at anything else other than an ideal angle.
How's that for a guess!!
I worked to get faster with a straight razor early on and that sort of ended my fascination with DEs, but far preferable to buying plastic junk for a landfill nonetheless. I can't seem to get anything else to shave without razorburn, but it seems that in the world of shaving, everyone perceives just about everything different (not making any statement about one way being better than another - they can both be expensive to experiment with, too).
If I know anything from interviews of old japanese razor makers (translated), I recall that they love the idea of taking an established design and then making the attributes of it better so that they can declare it better. I see this excerpt on one of the feather DE listings
>....ultra premium shaving tool, with exacting tolerances....<
It reminds me of tanifuji and some of the other straight razor makers of the time -rather than matching german razors, they pretty much attempted to make them a little bit better in every way that they could figure out (tanifuji's razors are exceptional - not saying that in a spec sheet audiophile kind of way that they're great because tanifuji said so, but they're great because they seem to be very easy to sharpen and keep sharp and they're tolerant of just about anything, and finished uniquely well.
I don't know if you could find out exactly what they did to make them work that well, but if you could get a hold of someone at the company that spoke english, they might tell you (and might not). I'd bet it's intentional and the result of experimentation and little improvements.
Those Japanese razors
Wiley Horne
Hi David and all,
I wonder if those vintage Japanese razors were made from iron-sand steel (tamahagane), because that was available from the port town of Yasugi at that time, and had been smelted since the 7th and 8th centuries. It’s mostly played out now, in commercial quantities, but the Hitachi subsidiary ‘Yasuki Special Steel’ may still make or try to emulate the iron-sand steel in small quantities.
Wiley
Don't know, but I get a couple of weeks or more from blades in my old Gillette. Well, more than that, because, now that I've graduated from work, I don't necessarily shave every day.
I used to use the blades from our local pharmacy chain, but then it was purchased by CVS, and the CVS blades are like shaving with a sharpened garden rake. I now use Merkur, just because that was what I picked from the vast choice offered by the online supplier I use. I'll try some Feather blades next time I need to order, in a year or so.
I remind myself of the survey some years back in which a majority of women found two days' growth of beard sexy...although I then remember that the women in question were probably not thinking about old men.
Howard Pollack
I'm with Derek, the Feather blades are the sharpest I've tried, and I've tried many.
Wiley - this is a can of worms!!
David Weaver
So, I don't know all of tanifuji's different steels. I've had three of his razors (still have two - one good one (that's all one needs), but all three of those have been marked silver steel or swedish. I can't tell the difference between them. The steel is just a bit harder than most german razors, but it's the little things about the two good ones I've had, including the one I still have - it's a little harder, it's a little more finely finished (as well finished as anything I've seen), it seems to respond just a little bit better, the quality of the grins is perfect (outside of japan, this went downhill pretty quickly with german razors and the grind quality in the 60s and later is pretty bad, coarse, quickly done...plenty of older american and german razors that aren't as straight as they should be ,too. Dovo company in germany says it's hard to convince people who are career oriented to spend the years that it takes to get good at grinding on a production basis)
I went on a binge two or three years ago buying stuff off of yahoo auctions in japan and keeping what I like. There are pickers over there who seem to constantly pull stuff out of retiring or retired barber shops (inexpensive really wonderful razor finishing stones, old unused german razors, old yasuki steel razors, and a gaggle of kamisoris, which someone in japan advised me are "sold mostly to foriegners).
I still have some yasuki razors, and I probably have some kamisori marked tamahagane that were $15 or so each in lots of 10 mostly because they just need to be reground (guess what CBN wheels are good at - not overheating kamisori and doing a neat job regrinding the hollow).
I have only shaved with maybe 5 yasuki razors that aren't kamisori, and they tend to be a little harder but still good quality. Guessing on really hard steel (like some european razors have done with boutique super high carbon steels) doesn't always turn out well.
All that said, the only razor that I'm aware of that's really sand iron steel is iwasaki, and they were always more than I'd want to pay (in western style - I had an iwasaki branded newer kamisori and nothing about it really stood out - I've had inexpensive older castoffs needing a regrind that turned out to be better shavers).
Needless to say, I still have a bunch of razors to unload - folks who are using linen and a strop will often probably prefer something a lot more like tanifuji's silver and swedish (or any good straight german or japanese razor) than they will some of the more really hard tempered razors that don't respond that well to stropping. There's a point (and I don't know what it is) where steel no longer responds the same to a bare leather strop, and it doesn't matter for tools, but it's problematic with traditional razor care and maintenance. plainness of steel is generally 10 times more important than tools, too, as even 01 makes a bum razor compared to silver steel drill rod (which is only slightly alloyed).
Kawai and Kato
Howard, the Feather blades are fantastic. Agreed.
But it is not simply that the blades are good - the razor is so good .. and so much better than others that it will take a blade which appears dull on other razors, and make it workable.
The question is why? My thoughts are on similar lines to David’s. In my thoughts, the bedding on the Feather razor -as with a hand plane - provides extra stability, as if the “roughness” experienced with the other planes could be thought of along the lines of chatter. Recall the old theory of the chipbreaker providing stability for the blade. It does that (and more, of course). Perhaps that is what we are seeing? Perhaps they were designed by Professors Kawai and Kato? :)
