Telecaster pair finished
David Weaver
One in limba, one in khaya. Both sort of outside the traditional fender for one reason or another.
The maple neck was a purchased neck, but everything else is hand made.
The mahogany guitar uses a nontraditional pickguard, so I just traced it and roughed it out with drill and gouges. This is not well received in the guitar community where on of the key indicators of quality is how clean the hidden cavity routs are (this is, of course, a very strange thing to fixate on.
Two telecasters https://imgur.com/gallery/qdUW01k
(Dark outdated looking area is my basement. I'm not much of a priss about shop or storage aesthetics).
Re: Telecaster pair finished
GolfSteve in Calgary
Nice looking guitars. I'm not familiar with electric guitars whatsoever, and I see one guitar is bound and one isn't. I like the look of the bound guitar.
I think it's unusual...
David Weaver
Thanks, steve...for telecasters to be bound unless they're some kind of thinline or deluxe model that comes with it.
I like the binding on mahogany - it protects the top edge, and it's not hard to do.
The limba guitar is more typical telecaster except limba isn't typical in a telecaster and it's traditional (not elite shape or any number of the variants fender has come up with to add an upcharge from the standard) body shape but with a belly cut on the back.
I've heard a lot of people complain about the square edge on the older standard telecasters and les pauls, but comparing the guitars that I've made (especially in a world full of acoustics and hollow bodies), I just can't see a guitar less than 2" thick with a roundover on the back edge as being uncomfortable either way.
This is the first guitar I finished with either wood. Limba is light, and the guitar is mellow (but still good resonance). The khaya guitar is more crisp, but I haven't soldered a jack on it yet and I doubt any of that stuff will amount to a hill of beans once the sound comes through the pickups. The limba guitar has semi standard fender telecaster stuff in it with a slightly trick switch and it sounds ...like a telecaster.
Will make a few more fender copies, then on to carved top solid bodies and hopefully to flat tops and eventually arch tops. This type of guitar is very easy to make, even with mostly hand tools - a good place to iron out the details since I don't use much so far as aids other than something to mark the stock or mark where I'll cut fret slots.
Re: Looking good!
Wiley Horne
Hi David,
The work and detailing is really beautiful. What I’d really like to know about is your interest in guitars. Trying to connect the dots between planes, pencils, guitars...Do you play the instruments yourself, or just like the challenge?
Wiley
Thanks, Wiley...
David Weaver
..I do play guitar. Not as much as I used to, and building horns in on the time to play. But I've played since I was young and was in a cover band when I was younger (no inclination to build anything back then).
Not sure of the motivation to build guitars other than I kind of like to build things that can be used. Tools, pencils, guitars...
It's a lot like building tools. If you use tools a lot, you can build good tools (great ones) without them being geometrically perfect in certain aspects. Certain things on a guitar need to be really close to perfect (the fretwork and the nut work, stability of the wood in certain directions), and other things can yield to be fitted to the critical items.
I guess a lot of it also comes down to wanting to build things and not being that interested in furniture or building furniture.
Hand Tool Reaction - General Public
David Weaver
"I guess you do what you can with what you have" or "I see what you're saying , but hey...it works"
So - I use imgur to catalog pictures
People can see what you post. I usually get a request to "see the shop", assuming that the people requesting are amateur guitar builders and they want to see what I've got to scab a few ideas. Perhaps some jigs or something that will make accurate work a little bit easier without spending huge amounts.
The reaction is generally like stated above when I say "I try to use mostly hand tools and do minimal router and spindle sander work when hand isn't practical."
I want the guitars to look in pictures "like the real thing" and from a distance, but I don't mind if someone can tell close up that there's a lot of hand work in the parts (or that the finish is rubbed instead of sprayed, etc).
Part of the draw (as wiley asked) is figuring out a way to make these things well where you're zoned in on the project the whole time rather than just trying to push parts through setups and sand out errors and shim problem joints. And part of the draw doing things by hand like that is also to prepare for doing better, finer and more complicated work instead of getting stuck making 100 of the same thing with different colors and pickups because the machine setup matches something specific (though that's not a bad business plan if one is going to try to be the 1 in 100 who can curate a customer list and get paid to make guitars).
I'd bet I could sell a few of these per year and make a profit, but it wouldn't be worth the trouble - having a business in the house isn't something I want. The magic of the internet makes it possible to find a small niche market of people who want something that's been done by hand more than it needs to be, though.
