Entry hall table for a niece: Part 6
We ended the last session with the drawer dividers installed ...
Everything was nice and square, but the more I thought about what I had done, the unhappier I became. Such an elementary oversight. I cannot believe I did it, and also that no one pulled me up for it. What was it? Two items:
The first was that the grain for the drawer dividers runs the wrong way. Although the boards are as close to quarter grain as possible, which adds to stability, they will expand vertically. That could cause them to buckle, and then the drawers will not run nicely.
The second is that I could have built in a way to close up the drawer dividers against the back of the (to-be-built) side lipped drawer fronts ... this is to be used as a drawer stop ... at this stage it would be necessary to add a filler. Not good.
So I re-did the drawer dividers. Here is the rear of the case. The drawers are left long on purpose ...
Provision is made for the dividers to be adjustable in length (to close up with the back of the drawer front). They are given rebates to slide further forward ... it will be necessary that they move around 15mm forward (to within 5-6mm of the opening).
The rebate is 2mm deep (the depth of the dados), and largely created with a cutting gauge. The blade slices away end grain, and the resulting splitting away makes it easy to chop the remainder.
Here are the dividers, further forward than before, and capable of moving a little more still ...
The plan was to glue up the case. However, before this is done, it is wise to fit the drawer fronts across the width (the height will be done at a later date).
This is the board for the three drawers.
Removing one end, the board is set on the case ...
It is now apparent that the front of the bevel, where it meets the drawers, is not straight. It is possible to see a small amount of flat ...
This is especially noticeable in this corner ..
This is fairly easy to remedy ... mark with a pencil, and then plane away the pencil marks ...
Perfect now ...
The other end needs no more than a smidgeon removed ..
The upper side is now treated the same way. Interestingly, this needs no work at all.
Time to saw the drawer fronts to size.
First step is to mark the middle point of each divider (since the lips will share the divider). The mark can be seen in the rebate ...
The drawer board across the front ...
Transfer the mark, and then saw the drawer front ...
This process is repeated. Here are the three sequential drawer fronts. You can just make out the breaks ...
I am happy with this.
And so, finally, the case is glued up (Titebond Liquid Hide Glue - reversibility and long open time). Looking like a trussed up fowl ....
#EntryHallTable
Re: Entry hall table for a niece: Part 6
Clarification, please
Jim Matthews
I have followed this project (including a well deserved break for OVOCNÉ KNEDLÍKY) since the design stages. My question follows: if the dividers and carcasses panels all have the same grain orientation, why would drawers be affected?
If they (the drawers) have a front stop, would not all seasonal movement be seen only at the rear of the carcasse?
My concern
Jim, the drawers are not directly affected. However ..
I do have a concern about this build. The 6mm inserts (spacers) on both the inside ends of the case have grain running horizontally against the vertical grain of the 20mm case. Movement in wood is across the grain, not with the grain. So, when the two pieces move (as all does), it will be in different directions. The question is what will happen with the spacer insert? The outcome I fear is that is will split, and that this will interfere with the drawer running smoothly.
I plan to reduce the width of the insert by routing out a 6mm groove through the centre. This should reduce/prevent significant splitting. The case is glued up, but a trim router will fit. I could widen this further if indicated.
The two central drawer dividers are good. Everything that could be done to keep movement under control in this built has been done. No worries there.
I would appreciate some feedback from all about these end spacers/inserts.
I think I understand..
Jim Matthews
If the joint is glued in place, it will attempt to shear?
It's my (mis?) perception that if you laid the dividers flat on the top and bottom carcasses sections that the grain patterns align.
The top and bottom sections *should* expand "fore and aft" with seasonal humidity changes. If the dividers have the same orientation, should they also run out "fore and aft"?
I'm pressing this point as I have a build in progress with similar concerns.
