Stanley #80 bent blade
Jonathan Elliott
Following up on Dave's post about tuning up his #80. I have an 80 that I bought a Hock replacement blade for which is a fair amount thicker than original blade. Before I knew better, I used excessive tension via the thumb screw (like a couple turns with a wrench :O ) to compensate for a poorly sharpened blade to try and get the plane to perform the way I wanted. Now I have a blade that is bowed along is width and when I try to sharpen it, the middle of the blade is completely missed. Should I try to lightly bend it back or just keep sharpening it back to flat? Thanks!
Re: Stanley #80 bent blade
David Weaver
I don't know the hardness of those blades on the C scale, but if they're soft enough to roll a burr, they should be soft enough to bend back.
If you have a machinists vise, that's what I'd use, and then finish on a flat surface if you'd like to.
Wiley Horne
Hi Jonathan,
Diagnostics: You want to know whether (a) the Hock iron is unusably stiff and will kink before it flexes, or (b) the blade was not sharp enough, would not pull a shaving, which then caused you to flex the iron past its elasticity limit.
You can answer this question. Start by going back to AlanWS’ remarks in the previous thread, where he talks about testing the sharpened iron by hand, before you put it in the plane. This is what you want to do. You can hammer or crush the kink out of the Hock blade, or else just sharpen one of the ‘wings’ of the Hock blade. Either way, get the Hock iron as sharp as you know how. Leave the hook off for now. Then test it by hand: either you can find an angle where you can pull a shaving, or you get dust no matter what you do. If the blade pulls a shaving at some angle, then you have gotten it sharp enough. If you get dust, put a 5 or 10 degree hook on it as Derek said above, and try again—if still no luck, sharpening is the problem.
If sharpening is not the problem, then straighten the Hock blade, resharpen, and try (again hand testing) to find a burr angle that will work at the Stanley 80 fixed angle. Thatiron has already been overstressed—it may or may not flex properly now. If it wants to kink again, get one of these thinner ones,
https://www.leevalley.com/en-us/shop/tools/hand-tools/planes/blades/69374-replacement-blade-for-stanley-number-80-cabinet-scraper
Hope this helps!
Wiley
Jonathan Elliott
Thanks for the suggestions David and Wiley. I'm still finishing up building my shop so tools are in storage right now but once I get them out I will see what I can do and post back on my success or troubles :) Dave's thread on his issues with the 80 prompted me to ask now. Appreciate it as always.
Jonathan
