Edge guards for gouges?
Jeremy Osner
It's easy to find plastic caps for putting on the ends of your chisels to protect the edges... Is there any such product that I could find or make to protect my gouges?
Re: Edge guards for gouges?
I haven't tried this, but it might be worth trying
You can get a liquid plastic that air-hardens, sold for protecting tool handles and the like. It comes in a can similar to a Pringles can, and you dip the tool in, pull it out, let it air dry, and repeat until you've got the thickness you want. I've thought about buying a can, wrapping plastic wrap around the end of a chisel/gouge/whatever, then dipping the end in.
But, again, I haven't tried it, and haven't read the safety instructions, so don't know if the plastic would eat the plastic wrap, and so on, or how effective a protector cap it would make. But you might look into it. If you do decide to try this, please report back.
Re: I haven't tried this, but it might be worth tr
Jeremy Osner
Thanks, is that the same as epoxy resin or something else?
Jeremy Osner
for gouges with sufficiently shallow sweep, I could probably just force them into the chisel protectors, they should deform enough to hold.
david weaver
They won't need guards if they're in a roll or rack. If you're not moving around with them, you'll prefer making a rack or cabinet for them so that they're easier to get to and so that you can see them to prevent any rust from progressing.
rum
Sold under the name "plastidip" (probably among others) - much softer than an epoxy.
Picture of a rack...
david weaver
http://www.cybozone.com/fg/wilson2.html
I tried briefly to find someone other than george to bombard people with (once in a while, I get negative PMs or emails - or posts - about saying too many nice things about George Wilson).
But, I couldn't. Everything I clicked on was either pinterest or some cheesy site trying to sell plans.
George was making guitars on his bench in the 1990s and not kitchen cabinets, so there's not a lot of open space. Mine are above my grinder in a cabinet that's french cleated onto the wall, and another one separate from there - but in easy reach and I can see quickly if they're rusting (which doesn't seem to occur in the cabinet).
the benefit to the cabinet is that it's cheap to make out of scrap, it closes, and it's got fixtures to hang chisels and carving tools inside and out. You can hang about 70 chisels and gouges in a 2x3 wall space.
Oskar
I made my own, by taking small blocks of wood, and using the gouge in question to split them, then, again using that very gouge, excavating a room for the blade. Remove just enough wood, so that you can close the split with the gouge in, then it will be a tight fit in the end. Then glue the split piece together and you are done. I can try to get a pic or two at some point if you are interested.
edit: I made these edge protections, although I have a leather roll, just so that when stuffing the roll in a bag or backpack, that the edges don´t cut through the roll
Warren in Lancaster, PA
We usually keep carving tools in a tool roll. When carving, we lay the roll flat on the bench and have the tools we are using loose on the bench. When done we roll it up again.
Curious about tool roll use
david weaver
Are the folks having trouble with cut tool rolls putting the tools into the rolls blade first? Or are you stuffing the handles into the slots? If the roll has good design and you're stuffing the handles into the slots, there shouldn't be any need to cover up the edges.
Re: Curious about tool roll use
ain't easy knowing where the #5 sweep is if all the tool points are stuffed into the roll. Every carver I know uses a tool roll as Warren describes.
Much carving goes on for some duration with nothing else going on. So a tool roll occupying a lot of bench real estate is not a problem. I find chisels in a rack more useful as it occupies little space and they are equally handy. The sub set of chisels commonly used fits in a rack.
The carver that made the handsome secretary in the Gallery has two tool rolls to hold his carving tools. We recently scanned the points to select a sweep for the rice carving I needed.
Jack Guzman from Maine
Lead flashing
I have made chisel guards with lead sheet used for roof flashing. Just cut to size ,wide enough to crimp the sides and long enough to fold over the edge of the gouge.
Re: Lead flashing
Jeremy Osner
That's a great idea, thanks!
Thanks for the name, that's the stuff
The consistency is more like the rubbery plastic coating you find on pliers handles retail.
Re: Edge guards for gouges? Wine corks!
Barney Markunas
I'll second the wine corks, both traditional and the new plastic ones work on smaller gouges and carving knives that I don't have in a roll.
Oskar
Oskar
This is the solution I talked about. Might be overkill, with the tool roll and all, but as I said, I don´t have to be worried about stuffing the roll into the backpack or whatever.
Also, nevermind the whimsy forms. Carved them all quickly in rest pieces of birch. Could of course be made in a more uniform and cabinetmaker-appropriate design.
Jeremy Osner
Wow, nice!
Wiley Horne
Hi Oskar,
Very handsome edge guards! I am guessing, but does the gouge shown have a long low bevel? When you receive a new gouge from the maker—Pfeil perhaps—do you alter the bevel or use it as delivered?
Thanks, Wiley
Oskar
Thanks Wiley,
the gouge in the second pic is a Stubai, it had indeed a long low bevel, on which I ground a shorter, a bit steeper bevel when setting it up. The other long bent gouge in the roll, a Pfeil, I use as it came. Time will tell if I keep them like that.
Re: Thanks for the name, that's the stuff
Rum
I use it to rebuild the soles on my slippers :D
Well technically I use it for a lot of things, including making anti-slip pads on clamps and other similar uses.. but it doesn't last forever[1] so when there's a bit that I'm afraid its going to go off I build up a worn pair of slipper soles a bit.
[1] It does however last longer if you push a piece of saran wrap onto it to seal it up well.
bridger berdel
I tried rolls a few times but they ended up getting cut through, or the tools fell out too easily as I have a pretty mismatched assortment with different handle sizes, etc. What is working now is chisels and gouges in wide shallow drawers and jobsite chisels in a box with dividers. In the rare case I need to take bench chisels or gouges onsite I use corks or something on the edges, bundle them on a cloth and tie it.
AlanWS
Here's how to make a tool roll from a couple pair of old blue jeans: https://www.marymaycarving.com/blog/2012/12/24/denim-tool-roll/ Mary May puts the handles in the pockets.
I don't know if this one is like Warren's, but it works. Mine hasn't had 20 years of wear, but it is fine after a few.
Jim DeLaney, Austintown, Ohio
Re: Edge guards for gouges? *LINK*
I use these. They're flexible enough to follow the curvature of gouge tips. The biggest ones will easily accommodate a 1¼" #5 gouge.
guards
