How to do these drawers?
I am planning another build as a wedding gift, this time a niece. She picked out this entry hall table, which she wants in Jarrah.
Straightforward enough build, with the case in mitred through dovetails the only tricky bit. I've done a few of these now, so know what lies in store.
There appear to be two drawers. The question is, how does one build drawers without handles?
I am not in favour (and will not do) drawers on runners. Or use those Push-it mechanisms, which are made of plastic and will last about 5 years, if lucky. I build traditional dovetailed drawers.
One idea I had was to incorporate the lower bevelled case edge/rail into the drawers, and use this as a handle. However, I foresee the difficulty in getting everything to line up perfectly. I like the concept, but not sure about the practicality.
Any other ideas for handless or, if nothing else, complementary handles?
Re: How to do these drawers?
Jack Guzman from Maine
Derek, How about an opening in the bottom where a person could start the drawers with their fingers?
I like that approach
Can you somehow extend the top molding subtly to provide a handle?
She's set you an interesting challenge.
Charlie belden
How about a pivot point in the center of the top and bottom of each drawer face.
Rather than a rectangular drawer use a semi circular drawer, the center of the circle being the pivot point on the drawer face.
Place pivot points on the underside of the top and the upper side of bottom of the carcase.
Now the drawer can be rotated say 350 degrees to almost full open, a stop placed on the underside of the top of the carcase to
A) Stop CW rotation before 360 when opening
B).Stop the CCW rotation when closing.
To open the drawer press in on the left side.
I can do an illustration if these words don’t convey the idea.
Clever
And, if the depth of the cabinet is more than the radius of the drawers, you could hide a few secret drawers in the back of the cabinet, accessible by pulling the cabinet away from the wall (or, better dropping down below the cabinet).
Wiley Horne
Along the line suggested by Jack, I would suggest direct finger actuation from underneath. Exactly how it’s done depends on how the bottom is put together. My real first choice is a tiny wooden grain-matched turning for a pull.
Bigger question (to me, at least): How are the legs to be anchored? Does not appear to be much meat at the case bottom.
Wiley
Bill asked the same question (on the Messages forum) about attaching the legs.
I've seen a few of these designs with legs screwed into the base, or the use of a metal bracket to off set the legs, again screwed directly into the underside of the case. Bah.
Two ideas: one low-profile, and the other more "table-like".
The low profile concept is to use staked legs into a stretcher, with is attached to the underside with a sliding dovetail.
The "table-like" concept is to join the legs with mortice-and-tenons to stretchers, on a splay. I did this on a coffee table for a nephew (who is, incidentally, the sibling of my niece). A variation of this is likely.
Thoughts?
Don Stephan
With a strong magnet recessed into the back middle of the drawer front, an iron "handle" held against the drawer front could pull the drawer out. Of course, where to store the "handle" and the weight limitation on the drawer contents would be problematic.
Or, the drawer runners and drawer bottoms angle towards the tabletop, with just a slight notch at the front to keep the drawer from sliding out. Lift up the drawer from a hole in the bottom and down/out slides the drawer. Course, not much volume in the drawer, but the furniture factories, and millenials are focused today on look, not durability or functionality.
Thanks for all the replies. They really helped consolidate my thoughts.
I found the original piece on the web: https://www.coxandcox.co.uk/chevron-oak-console-table
It is sold as a flat pack, and poorly constructed. Although the advert states that it is solid oak, it looks veneered ply/mdf to my eyes (the grain on the drawer edges is more obviously veneer, not just the planted fronts, but the upper edge).
If the drawers need a push-it mechanism, to propel it out a few inches, the drawers will need to have reduced friction, and this means they need to be on metal runners. Like kitchen drawers. I have emailed my niece to explain this and that this is a low quality option.
I really liked Charlie's idea of semi circular drawers. I would like the challenge of building them (I came close to building drawers like this in the Harlequin Table). However, I think they are impractical. Fun, but impractical. I have suggested to my niece that the hall table uses more traditional drawers with unobtrusive handles.
The overall design is clean and quite nice. It could benefit from more refined details. That will be my contribution. I need to retain the look of the legs, but with a different undercarriage. The current design likely utilises metal connectors, something like these ...
They are likely quite strong, but a more refined construction would use a sliding dovetail with a staked mortice-and-tenon. This should add a lot more meat under the legs and still retain the slim profile ...
AZ in Colorado Springs
How about a small lever that protrudes from the bottom of the cabinet for each drawer? There would be a pivot/fulcrum in the center of the thickness of the case bottom, and a small block affixed to the bottom of the drawer. Pushing the lever towards the back slides the drawer out a couple of centimeters (or as we might say, an inch) so you can put fingers under the front edge of the drawer to fully open it.
If the drawer bottom is flat all the way across, then this could be installed at the back and far left and far right sides of the drawers, so a short groove or dado could provide clearance for the mechanism.
Les Groeller
How about cutting a hand hold, say 3 fingers wide by 2 fingers high in the front of each drawer and then re-place the cut pieces back into the holes, supported by hinge from the inside of the drawer of some sort. Jarrah is dark wood right? The cut lines might be barely noticeable.
