How it came to pass
This thing has wound up a long way from where it started. Over time as daughter modified her desires it became more Shakery. And then the bottom panel doors moved it moderny. Essential was glass in the upper doors that would hide the stored dishes behind them, the opposite of a typical corner cupboard. Patterned clear glass looked too busy or too commercial or too transparent.
Stained glass pieces leaded together was having a difficult time being compatible with the rest. No proposed design worked. Literally hundreds were rejected.
And then a local assembler of stained glass stuff told me that a wholesaler in Asheville might have stock panels that could fill the 35" height of the top door. Whoohoo, vertical battens would uplift the otherwise squat shape and opportune selection of glass would add to the design. However, cutting long narrow panels of this kind of glass is a crap shoot. I told the owner of the glass place that at this point cost was not an object. Cut till we get 8 good panels. It took 12 to get 8 that didn't break out from the scribe line.
If I can get it safely delivered to KY and installed I can relax.
