Corners of gouges
Corners of gouges
Corners of gouges
Jeremy Osner
I have a bad habit when sharpening gouges, I oversharpen the corners (where the edge meets the side of the blade) and round them off. Anybody else do this? Strategies for avoiding it?
(In some situations rounded corners seem like the right thing -- I've got a very low sweep 3/8" wide gouge that I'm using to carve the background of a relief carving, and not having corners is working well. The edge is sharp all the way to the side of the blade, not sure how I managed that.)
Re: Corners of gouges
david weaver
Intentionally sharpen the center of the gouge first and the corners last, or perhaps an easier way to start is intentionally undersharpen the corners at first and then finish them as a last step.
what are you using to sharpen the gouges, I guess is question 1. If you're using something like oilstones and a sweeping motion to sharpen the gouges, it should be pretty easy to preserve the corners. If you're using something very fast to set the geometry (or power), i'm sure it's easier to remove them.
I have never bought top flight carving tools (good era neatly used addis, etc), but have a bunch of henry taylor and buck carving tools, and exceptionally few have made it through their last owner with good geometry and sharpness at the same time.
Some guidelines from hobbiest experience.
Chuck Nickerson
If your corners are pulled back unintentionally, those areas are spending too much time on the sharpening medium. The middle of the cutting edge being pulled in also happens.
This is much more likely to happen with power grinding and power stropping.
When I resort to power grinding or stropping (less over time) I am often checking the bevel's leading edge against a piece of poplar for flatness or straightness or whatever word works for you.
The few very serious carvers I know have a few gouges with the wings pulled back or pushed forward for those rare times it help speed up the carving.
