I continue to be amazed by XHP
david weaver
It's not like it's magic, I guess, but all of my metal bench planes are fitted with it.
The washita that I used for durability testing (that posted a good number) is enamored with it as a finisher - it finishes more finely than carbon steel on that stone, and it continues to deliver a super bright finish.
I've been tardy on compiling the report document, but it's busy time of the year for me at work for at least the next month.
Never received a response from SB metals about whether or not they could provide me with ground .140 material, so I'll assume the answer to that is no. Which is a bit of a disappointment as I'd love to dump it in two of my infills.
Re: I continue to be amazed by XHP
I found its limits
david weaver
last night, planing the outside of a spruce guitar blank (the end grain). intermittent cut, relatively heavy, mouth somewhat closed (using a smoother).
Normally, this is one of the few things that I do with power tools (template rout the outside of the guitar body after everything else is done by hand), but spruce doesn't afford the ability to do rough work around the edges like a big router bit taking a bite off - it breaks off somewhere and that kind of thing isn't acceptable on a guitar body.
At any rate, that resulted in an iron with lots of nicks, though I can't say for sure that carbon steel wouldn't have also nicked.
The job is one for a spokeshave, anyway.
I'm convinced (and didn't test that during iron testing) that a tight mouth and tight cap leading to restriction is something that actually damages an edge. It's not the first time I've seen this. Another reason to give the mouth a little more room and get it out of the way of the cap iron.
Should clarify about the mouth and the cap..
david weaver
..I don't think it's just the cap iron being involved with the interrupted cut, etc, I think it's a cut like that with a tight mouth in general. I think anything that causes the shaving size to challenge the size of the mouth damages the edge of the iron pretty easily with deflection and nicking.
