Cutting scrapers from a saw blade
Jeremy Osner
Has anyone done this? Over the course of making my violin I'll have need for a number of small odd-shape scrapers, and I have an old crosscut saw or two that I could sacrifice. What would be the best way to cut the scrapers out, with a dremel tool? Would tin snips cut a saw blade?
Re: Cutting scrapers from a saw blade
Bruce, a MN Galoot
Tin snips will not work. At all. A Dremel is just right. Be prepared to go through several cutoff disks, though. Smooth out the curves, turn a burr and you’re good to go. I have a half dozen, at least. The neat thing is you can so easily customize what you need.
Frank House
Agree re. small cutoff wheel.
One can buy metal-cutting blades for fretsaw/scrollsaw and small bandsaws. I have not tried them for this application.
Subsequent shaping with files is easy.
Final edge treatment for complex shapes can be done with slipstones, fine abrasive paper/film wrapped around sticks, slips of hard wood with embedded diamond paste, carbide fragments from broken cutting tools, etc.
As others have pointed out on this forum, you do not need to turn a burr to get efficient scraping, but the shank of a small twist drill can do the job.
I have made scrapers from Japenese-style pullsaw plates and from Western-style backsaw plates. I prefer the former for fine detail work -- YMMV.
David Weaver
I have used a hack saw to score them and then broken them at the score line and finished them with a file.
Hamler's suggestions
As reported earlier Paul uses a Dremel with cut-off blade. He gets much longer blade life if the steel is waxed along the cut line. An alternative that ensures the best metal for the task is to buy some "blue" 1095 from any machine shop supply place, MSC for example. The best saw blades are perfect , according to Paul if you know for sure the blade is "best" and you can find one not pitted.
If you have shop near by with a shear this is the best way to make blanks.
Re: clarification of hacksaw use
david weaver
Extra clarification on the hacksaw (as I think dremels are a waste of time, and fiddly with the disks).
if needed, secure the metal you're scoring under a piece of wood and cut up against it.
In my opinion, the lenox 18 tpi blades with no wave in the toothline are an essential thing to have in any woodworking shop. Sooner or later you'll cut something, they're bimetal and painted so if it takes forever for you to do it, no big deal (they won't rust). They're about $5 for two, and one on its own will literally do all of the metalwork for an entire infill panel plane (including comb cutting).
The scoring cut is not into the metals thickness, it's along its width. Easy, then file the edge. I've done this with old saws and new 1095 without issue, and use the same lenox blades to cut out plane blades.
You can just cut part of the blade and then bend and break it like you would with a dremel, or you can do as I do and just cut all of the way through.
Most other blades that I've tried are junk, even when they're labeled HSS, they will not tolerate cutting thin or hardened steel. The teeth will either break off or wear off.
William Duffield
Maybe it's an old wives' tale, but I understand that Disston improved their metallurgy as time went on, and therefore newer saws, with regrettably less comfortable handles and made from cheaper wood, have the best steel for scrapers.
Note also that you can make small scrapers from bigger scrapers. To that end, I understand that Bahco and Lie-Nielsen scrapers are made from Swedish 1095 steel, while other (predominately English) brands are probably made from lesser steels, maybe 1085 or 1075. Of course they don't tell you what they use, but I have noticed that my Swedish scrapers tend to hold an edge and a burr longer than the others I have.
