Moravian hexagonal drawer
This site has been a bit short on working wood. Shown is a picture of the hexagonal drawer that goes into the corner cupboard. I don't know if it is a Moravian drawer but it does use angled dovetails that the Moravians used in their furnishings, so it might be. These joints settle the issue of pins or tails first. One option is impossible to transfer the pattern. Another issue is holding the pieces together for transferring pattern from pin board to tail board. I came up with solutions for building the drawer and later found what I did was what was believed to have been done, maybe because there isn't another way that can be readily executed.
Sloppiest joints I ever included in a piece of furniture. Some geometrical considerations result in small sawing errors becoming big gaps upon assembly. But I got tired of perfecting the joints and what I have will hold the drawer together.
It was so much "fun" struggling with angled dovetails that I made a trapezoidal box to go behind the drawer as a secret drawer.
Re: Moravian hexagonal drawer
Very cool
Jim Matthews
Nearly done.
No need to dwell on flaws with such strong work.
Kudos
*typo*
Jim Matthews
Should read *neatly*
Clueless autocorrect and poor vision
Among the items in my parents' house when we cleaned it out was a small 19th century chest of drawers, probably factory made. The dovetails looked like they'd been chewed out by badgers, but the drawers were still intact and working fine, a probable century after the chest was put in use.
I think the current standard of perfection in dovetails is probably based on the pieces that made it into the museums - the equivalent of saying, "No point in playing soccer unless I can be as good as Megan Rapinoe or Lionel Messi or [insert name of your favorite pro soccer player here]."
I agree: that's a really neat drawer, and I applaud your decision to hide a little drawer behind it. Given the shape of the opening, how will you get the hidden drawer to align and stay in place?
Drawer is center under mount rail. Hidden drawer rides on this rail just like the main drawer. A leather pull provides a place to pull it, yet lay flat. It all works fine.
William Duffield
It seems like you have room for two more, one on each side of the main drawer (now that you have plenty of practice with the dovetails :) ).
That opportunity has not escaped me but I had nearly pushed it out of my mind until your reminder. >( I may do it if the memory of fighting with the secret drawer becomes dimmer. I made every mistake I could on that simple box. I have a stack of miscut parts form the adventure.
Don Stephan
Sounds like an article!
William Duffield
It doesn't work that way, at least not for me. I have to jump right on it if I'm going to be inspired by my eventual successes in overcoming adversity. The longer I put it off, the more the happy parts fade from memory and the more the the pains and failures are burnt into my psyche.
