I have a knife blade that I'd like to to set in a wooden handle. I've never done that before. How would I go about it? The blade is very skinny, it's 1.8mm by 4mm, 5 inches long. I was thinking about getting a long 2mm drill bit and drilling a mortise for the blade but it seems like it would be really difficult to keep the mortise straight? Maybe I could do it if I clamped the handle in place on my drill press -- the wood I want to use for the handle is currenly square so that should be feasible. Or the other thing I could do is cut the handle in half. cut out a mortise with saw and chisel, and then glue it together. That is sounding more reasonable idea as I think about it.
Any other way of doing this that I'm missing? The knife is a "western pattern blue steel woodworking knife" from Japan Woodworker.
Start with two "scales", pieces of wood for each side of the handle. Some burl or crotch wood is nice for this task. Mortise out 1/2 the blade thickness in each. Put knife in one half and drill through the rivet holes in the knife. Assemble and drill through the scale with the holes through knife and through the other scale. Gob in epoxy, assemble, drive rivets through the holes and tape to hold together until it sets. Shape and polish. Soak in linseed oil until saturated.
Watch "Forged in Fire" on history channel, they make multiple knives each episode.
Best results appear to come from those that use a pair of scales epoxied together and held in place with a pin through the scales and the tang. Problem is that most of the hardened tangs are so hard that the bladesmith cannot drill a hole through the tang that does does not compromise the tangs strength. Annealing the blade so drilling could happen compromises the tang. Several blades have failed do to this problem. But then again they are typically testing the knives in a violent way such as ice block chop etc. If the knife is used in carving (whittling) epoxy may be enough.
I have done the mortise method you describe, making one half the handle thicker than the other by the thickness of the knife shank. It works. A little messy, because you will inevitably have some epoxy squeeze out, but that is manageable.
Here is one other possibility: Years ago, I received from the amazing John Aniano this ‘bamboo leaf’ knife, made from a file and leather:
This is the most satisfying handle covering ever on a skinny handled tool, in my opinion. Of course, there is the animal factor which I won’t get into.....
Wiley, thanks for the kind words regarding the knife I made for you! Hope you've mad good use of it.
Jeremy, to cover a knife blade with leather, just cut it carefully to fit and use scarf or tapered thickness joints. A sharp blade (razor blade) can be used to taper the leather from the back. Cut into a hard piece of maple or even glass to get a nice clean scarfed edge. Use white or yellow glue on the leather back and carefully affix the leather to the knife blank. Use wide rubber bands (cut into a strip) and wind around the leather to clamp it in place while the glue dries. When done, remove the rubber band clamp and wipe with a damp cloth to remove any squeezed out glue. Done!
If you wanted to make wooden scales, check out my web page showing how to make and install a wood handle. It's easy!
I've always assumed that type of knife was intended to be use without an additional handle, but it's yours and a handle might make it more comfortable & controllable.
Several suggestions of different techniques. First of a couple I've heard of & didn't see (yet, probably get posted while I'm typing ) are to start with your mortise hole and then "burn in" the tang. This is very traditional, but tangs intended for this approach tend to have a taper I don't see on the Japan Woodworker image. You heat the tang and burn out just enough wood for a snug fit. (I've never been tempted to try this as I assume I'd screw up the blades temper.)
I bookmarked another way to enlarge and shape a drilled mortise: "Make yourself some broaches" at Blade Forums. (Link below, I hope.) It seems ideal, but might be too much work if you're only doing one knife.
Another, much less traditional but easy, method is to drill out an oversized hole and get a dowel to fit snugly. You can then split, carve, and do pretty much anything to the dowel to hold the tang well. But when you glue it into the handle all that is (mostly) hidden.
The name for your blade is Kiridashi. Quite commonly, these are used without a handle. I have a couple like this, and find them easier this way since they can lie flat on the work surface ...
Your idea of hollowing out one side of a wooden blade, inserting the blade, and then epoxying the two sides together will work. I have done this as well.
If you have a lathe, this is my preferred method ....
Shape a handle you like. Grind the rear of the kiridashi into a tang. Drill the handle, and secure the tang in this with epoxy ...
I infilled the hole at the end of the handle with a piece of brass rod ...
Re: Putting a wound lapping "handle" on a knife...
John Aniano in Central NJ
Jeremy,
How about wrapping a substantial thread, cord or twine on the handle portion? Now that would look nice! I'm picturing a black cord, maybe 1/16" shy diameter, nicely wrapped. You've got to do the ends properly, so they look nice. There's a simple trick to doing them, called whipping. Maybe add a contrasting band of gray near the ends. Finish with black at top and bottom. You could even dual wind the gray and black threads together for the middle. Now THAT would be quite classy! And provide a good grip...
Actually, doing all those variations is pretty easy. Do you still live in NJ? If so, and if you have the time, come over to my shop and I can show you how it's done. Even with two or more colors! I do it all the time on bows...
There are lots of different ways to handle a knife. A lot depends on what tools and raw materials are in your tool set. Really good advise using many different methods can be found on Walter Sorrells' YouTube channel.
Jeremy Osner
That sounds like a great idea, both the idea of using cord for the handle and the idea of me coming over there to see how it's done. Maybe next month sometime, I'll be in touch.
Jeremy Osner
Thanks for the idea and the lesson, John! I ended up using wax linen thread in purple and black. I may need to redo it -- will see if this holds up or unravels -- but if so I have a pretty good idea of where I went wrong. Very comfortable in the hand!
