edge pictures from end grain testing
David Weaver
see each sub-post
Re: edge pictures from end grain testing
V11 edge pictures
David Weaver
Each picture generally represents 200 passes, or about 146 feet of planing:
* freshly sharpened
*200
*400
*600
*800
*1088 (forgot to take a picture at 1000)
Re: O1 edge pictures
David Weaver
* freshly sharpened
*200
*400
*600
*800
*1013
Looking at the pictures
David Weaver
it doesn't really appear that there's a smoking gun for dullness. The edge appears to lose definition later in the picture set, but if you look closely, I think you can see that the thickness of the edge itself is increasing due to roundness.
What happens with the photos when this occurs is that the light fails to reflect back and as the edge falls off into roundness, you see a dark shadow, and that's it.
Each iron didn't end the same way. The V11 iron started to skip, and the O1 iron just got too hard to push. In the long grain testing, they all failed the same way, so it was easier to gauge that the test would produce identical results each time. This one, I can only observe what happened.
I would've sharpened half of the way through this length of wood planed as both become hard to push. Though the V11 was a little less hard, it was still fatiguing.
Thankfully, due to my obsessive use of planes, yesterday's twitching shoulder didn't even lead to minimal soreness this morning.
