I'm looking for a veneer saw for thick veneers, about 3/32". I see that TFWW has one specifically for thick veneer, but it's priced at about $150. Can anyone recommend a less expensive saw for trimming thick veneers?
There is a Japanese model that cuts on the pull stroke. Called an ‘azebiki’. Use it against a straight-edge. Cutting length varies typically from about 2-3/8” to 4”—i.e., 60mm to 96mm. Here is one from Hida Tool,
There are many of them on Ebay, priced generally from $30-45.
They are toothed for rip and crosscut. Generally about 15tpi xcut; 9tpi rip.
It is very useful to have both rip and crosscut.
I have used these for thick veneer—they work well, and in a rip will plane up long curls.
Other option for rip: fine tooth blade on band saw, then shoot the edge. Repeat: fine tooth, slow feed.
Depending on the hardness of the wood, you might be able to get by at 3/32 with a cutting gauge, but they can be tricky to use for the purpose, because you really have to bear down, even with a sharp gauge, and the work can move if you’re not holding your mouth right—damhikt. Plus, the gauge will want to grain follow, so it can get messy. Am telling you my failures as well as successes .
Bill, I've taken the exact same approach and had very good results, I was just looking for something that would make it easier to work with small pieces and odd angles. As an extra benefit I can work with a veneer saw in the middle of the night without making too much noise.
