ln a2 at 50 shavings
david weaver
freshly sharpened
50 shavings
excellent surface quality
no defects
Re: ln a2 at 50 shavings
Corrected 50 shavings - wear picture
David Weaver
The wear picture isn't correct in the prior post for a2 - this is it:
Re: ln a2 at 100
david weaver
at 100 shavings. excellent uniformity still.
visible wear but still staying in the cut without front hand pressure
Re: ln a2 at 150 shavings
david weaver
still cutting but the edge is beginning to crumble. there are noticeable lines on the surface and the shavings are beginning to split a little bit. uniform across the width getting substantially worse as this 200 feet of planing was completed.
this is familiar from years ago when i tested a2 irons - there was a sudden loss of quality that rapidly appeared and then continued to get worse and worse.
these are the first lines that you an feel with a fingertip or fingernail.
the interference pattern
You are seeing an interference patter describe by......yup- K&K. I think I have a translation of what is causing it....as I recall with some risk of error..... a reflection off a wear surface that is developing behind the edge.
Re: the interference pattern
David Weaver
I probably should've been more clear that the lines I'm seeing are on the surface of the wood, and not those cartoon like lines behind the wear bevel on the iron.
Are those interesting pattern lines on the iron (the ones that almost look like the lines you see through a lens used to check flatness) the ones you're referring to as an interference pattern?
The edge of the iron for this iron looks rough, but only slightly so on the 100 stroke picture, and then the decline is very visible here at the cutting edge - rough edge forming with the more typical wear (like the neatly made wear on the O1 iron) behind that but receding.
PIC sent to you
needed a higher res. pic so I didn't try to =post
Interferometry and optical comparators
Jim Matthews
Is that describing Moire patterns and other interference at 400 - 700 nm?
Are the boundaries that small on sharpened steel?
No wonder desirable tool steel characteristics are so difficult to describe.
