The Harlequin side table: legs
The case was completed last time ...
... but before the drawer dividers can be permanently installed, the legs need to be made and attached.
This was the original drawing ...
Some has been retained and some has been changed.
Instead of curved legs, which I later decided did not match the overall style, I decided on round, tapered legs that will splay out from the case.
Before turning the legs, the splay was created by tapering the top of the legs on the table saw. The slider uses a Fritz and Frans jig to rip the end at the chosen angle (8 degrees). This ensured that the splay angle would be the same for all legs.
The blanks were then turned to shape. Here I am checking that the near-to-finished legs are the same dimensions and have the same taper angle ...
The ends were then cut off and the top was shaped with rasps and sandpaper ...
How to attach the legs? Well, that had given me a real headache. I was thinking along the lines of a loose tenon ... overcomplicating matters (as usual). A number suggested simply glueing and screwing. I was skeptical, but of course, a glue joint alone is generally stronger than the wood ... and reason prevailed :)
There are three screws per leg, which were countersunk for the drawers. The glue chosen was Titebond III.
All cleaned up, this is what we have (drumroll) ...
The splay to the side is 8 degree, and from the sides, the legs are aligned with the front and rear of the case.
Drawers next :)
Re: The Harlequin side table: legs
Last images for a while
A frustrating Sunday: I began installing the horizontal divider/drawer blade, and my spatial confusion (or lack of concentration) kicked in. In went the divider ... upside down! Well, fortunately it jammed half-way and could not be glued in ...
Knocking it out, however, caused the rear section of the panel (it is made of three boards) to break off. It was glued back again, but the panel needed to dry before starting again, and so I lost my Sunday afternoon. This table is destined for the Perth Wood Show at the start of August, and I am already battling with time as weekends are generally all that are available for woodworking.
Fortunately, I had this afternoon (Monday) off from my practice, and had a couple of hours to try and catch up a little.
The glue dried, and the panel was fine. It was sanded to 240 grit, and then installed. Ditto the side dividers. All went smoothly ... all lined up and everything is square. Clearly I have been a good boy :)
The reason why the table is termed "Harlequin" is that the drawers will be a mix of different timbers: Black Walnut (x3), Figured Hard Maple (x2) (both from the USA), and Tasmanian Blue Gum (x3) (which is local, of course).
The drawer fronts all curve, and I spent the last part of the afternoon cutting out the Walnut blanks. This will will give you an idea of the effect ..
Unless someone is interested in a walk through in dovetailing on the curve (which I have posted here previously), the next images will be the completed table.
