I was at a MWTCA tool meet last weekend and purchased a draw knife that was missing both handles. I want to practice making handles for it and also learn how to use a draw knife.
Question 1: I think I remember a post or an article from the last couple of years that had a really good and detailed write-up on making handles for a tanged draw knife. I tried searching for it, but I can't seem to find it. Does anyone recall this or have the link? I thought it was by Derek and looked at his site, but I couldn't find it there either.
Question 2: I was trimming my apple trees today and cut off a couple of large limbs. Can these be turned into handles while green and dry on the draw knife without issue or do I need to rough them out and then let them dry for a period of time before mounting?
One of the experts can tell you more but my instinct is that green wood might split. You could cut the pieces in ruff, microwave them til dry and then mount. Plans? Isn't that your choice? Mine have flats but no one else seems to have anything but round handles. P
I don’t know where the saw tote makers of your got their apple, so big and split free, but I sure can’t find any. I got a piece of apple from a friend, and it checked badly. I would wait until it fully dries.
There is no problem using green wood for this. I recommend splitting a branch down the middle or into quarters to get nice stock. A piece of a branch that contains the pith is vulnerable to heart checks. If the pith is near the edge of your stock, it will probably split from the pith to the nearest edge, but will otherwise be sound.
An apple branch that grew at an angle will have compression wood on the underside. This is a form of reaction wood. The tree makes extra wood on the underside of the branch in order to counteract the tendency for the branch to droop and there can be three or four times as much wood on one side of the pith as the other. Also such a branch can distort a bit when it is cut open.
Green wood cuts cleanly with sharp tools; I don't recommend filing or sanding.
Thank for the suggestions. After cutting a section from a branch and splitting it, it appears that the center pith is too large to get any useful wood out of it. I happened to have some mulberry out in the woodpile and I think it has better wood.
I think what you are calling the pith is the heartwood, which is fine. The heartwood is a reddish brown as opposed to the sapwood, which is creamy. The pith on an apple tree is about 1/16 inch in diameter. It would be hard to find if it were not at the center of the annual rings.
Yes! That is the post that I was looking for. Unfortunately, I was using "draw knife" (with a space) in my search and missed Brian's post. I'll remember next time to try different variations on drawknife, draw knife, drawknives, etc. We have bad weather today, so I'll head to the basement and play.
