Railroad spike
Railroad spike
Railroad spike
Jeremy Osner
I found a rusty old railroad spike by the tracks today... It looks like it ought to be turned into a tool. Anyone have uses for old railroad spikes? I guess it is probably way too soft to make a useful edge tool?
Re: Railroad spike
Re: Railroad spike
John Veerkamp
can be used as a small wood splitter for fire wood to free a larger stuck wedge.
Re: Railroad spike
Re: Railroad spike
Kevin French
We cut them at around 3", drill and tap them then screw them thorough a horizontal wine barrel stave with 4 or 5 other ones to make coat hooks
Re: Railroad spike
Re: Railroad spike
Philip F Duffy
Some spikes have a pretty good level of carbon, others not so much. If you look on the top those with will have a C marking (as I remember). They hold a great edge and many knife makers use them for custom knives.
Re: Railroad spike
Re: Railroad spike
TomD
If you have a power grinder, or a high speed disc sander that will generate sparks, you can tell how high carbon it is from the form of the sparks. No doubt there is an online video for that. Also, with lower C, you can harden in Super Quench, but you will normally get say hammer levels of hardness.
Re: Railroad spike
Re: Railroad spike
Wiley Horne
Maybe a small anvil. Drive it into something heavy.
Wiley
Re: Railroad spike
P.S.
Wiley Horne
Maybe Ellis could have a Railroad Spike Challenge. Winner gets an 8-lb hammer, reportedly one of the two used by John Henry.
Wiley
Re: Railroad spike
Re: Railroad spike
William Duffield
That's what I use mine for. A warning: Don't do as I did, and try to hold it in your vise while beating on it. It's not good for the vise jaws or the vise mechanism or the vise mount. Like Wiley suggests, drive it into an elm stump and set it somewhere very solid (like a Roubo, directly over a massive leg) while you are using it.
Re: Railroad spike
Re: Railroad spike
TomD
Exactly, perfect for a peening anvil for your scythe.
Re: Railroad spike
Re: Railroad spike
Bruce, a MN Galoot
If you have metalworking skills, a spike knife would be one such project.
Re: Railroad spike
John Henry
Ray Newman
John Henry! Now that is a name I have not heard mentioned in many years.
Re: Railroad spike
Re: Railroad spike
Jeremy Osner
Thanks for the ideas! From the spark test it looks (if I'm understanding the video I watched correctly) like low-carbon steel. I reckon I will make it into an anvil.
Re: Railroad spike
Re: Railroad spike
Rum
I have a couple of the higher carbon ones I've ground and polished the tops then made the bottom a bit sharper so they work "ok' as scythe peening anvils.
Re: Railroad spike
Re: Railroad spike specs, and dragons
TomD
http://www.anvilfire.com/article.php?bodyName=/FAQs/rr-spike.htm
These are some RR spike letter openers I found online:
I never got much past start with forging, since all I really wanted was to heat treat. But I did try a few minor projects, and and anvilfire.com has good instructions for things like dragons. I tried the moves out first with my kids' wooden hammer, and some Plasticine.
Re: Railroad spike
We need a champion for that little project, Wiley
Sounds like a great idea. I'll check with Ellis when I see him again. :)
