A coffee table for my nephew - #7
Finishing the base ..
Splayed legs leave their tops angled with the rails, and they need to be flushed ...
... to be coplanar on both sides ...
The next step was to add corner reinforcing blocks. These were glued and screwed ...
You can see they follow the angled rails (created by the splayed legs).
The under side ..
The final stage was to level the legs. Measure the height at each corner, and use wedges under each leg until the height is the same for all ...
Hot glue the wedges so they do not move ...
Once done, scribe the bottom of each leg ...
Electrician's tape is great for marking at an angle ...
Saw off the waste, and we are done ...
I checked the result with a digital angle box. All good. Sanded to 240 grit ...
The drawer and finishing is left to do.
Re: A coffee table for my nephew - #7
david charlesworth
Nice work.
A little bevelling of the feet to prevent spelch if the table were dragged over a hard surface?
David
Thanks David. I did knock the edges off with sandpaper on a hard block, very finely - may be difficult to see ...
david charlesworth
That's good technique!
David
