Bird cage windsor
Bird cage windsor
Jack Guzman from Maine
Bird cage windsor
Curtis Buchanan finally came out with the plans I've been anxiously awaiting. The Bird cage arm chair. I made the jigs and bending forms,watched the instuctional videos and prepped all my materials. I finally finished my first attempt at this beautiful chair. My favorite of all the Windsor chair styles I have seen. I had a few missteps but overall the build was a success. Here is a picture of the unfinished but completed chair. It is a flawed example ,but I plan to paint it mustard and green and keep it.
Re: Bird cage windsor
Kevin Adams
Beautiful work, Jack! Please post pic after you paint, nicely done.
Kevin
Re: Doesn't Look Flawed to Me!
Hank Knight
Funny how our flaws stand out like sore thumbs to us, but nobody else sees them.
That's a beautiful chair, Jack. Well done!
Philip Duffy
Stunning and beautiful, Jack! BZ Phil
Very nice!
Warren in Lancaster, PA
I had a friend who made Windsor chairs for a living, over forty years before retiring a few years ago. He once showed me his first chair, made around 1970, and asked if I noticed anything wrong with it. I did not. Then he pointed out that the arm posts were very different; the turning elements were mixed up.
Wow, gorgeous, Jack! I'm sure your long experience made it easy.
How will you do the painting and finishing?
Not sure I understand your question. If you mean how long to paint it,it's about an eight day process. If you mean when will I do it, starting tomorrow most likely. I will post a picture.
I plant to Kevin,thanks
One of the first things I learned as a woodworker is how to hide flaws well. thanks
Thanks
thank you
GolfSteve in Calgary
Wonderful. Windsor chairs are on my too doo list (for 10 years now).
Very nicely done!
Chuck Nickerson
I have yet to make a Windsor outside of a classroom setting.
I need to put that in my Q2 schedule.
I was mostly wondering what materials you use, how the two colors go on the chair, and what you top it off with. Mike Dunbar advocated milk paint followed by Waterlox or something equivalent. That's what I put on a chair of his about 25 years ago, and it is looking suitably funky to me. Seems like the wear pattern is part of the authentic looking finish.
For what it's worth, Stephen Shepherd never agreed with milk paint for period chairs. I was just wondering what finishing regime you favor.
Cheers,
I have read Stephen Shepherds info on milk paint. I still use it. I like the look and I like working with it. I usually stain first with walnut natural stain (extract from soaking walnut shells)to darken the base wood. Then I paint on as many coats of milk paint as it requires to get my desired look. Once I get the color or colors I want I rub it out to get it somewhat glossy,then add the finish coats. The finish is wipe on,consisting of spar varnish,blo and mineral spirits in equal parts.
Brian Holcombe
Cool! Nicely done.
John Aniano in Central NJ
Hi Jack,
Super looking chair! Very nice! I like the extenuated corners at the top of the back rail.
Are the armrests your own design? Are they Buchanan's? They look a bit modern in spirit as compared to the rest of the design. Maybe it's just me...
And are the back spindles turned or rived/spokeshaved? I think I see a tiny bamboo turned element in each spindle at the armrest height - are these elements turned or carved? And are the back spindles steamed to achieve the tapered splay?
John
To answer your questions, The design of the arms is from Curtis Buchanan. The spindles were riven and shaved to shape,steam bent when in the square. The grooves in the spindles to match the "bamboo joints"in the chair are carved after shaping. It is a very interesting chair to craft.
You do really nice work, Jack!
Bruce, a MN Galoot
Betcha I couldn’t find those few flaws.
Color selection?
Clementine
I seem to recall that furniture of the Revolution period was painted, not stained like today. Is there an "unwritten rule" on color selection of a Windsor. Mustard and green sounds like a winning match to me. Just wondering about what they did back then and their rule of thumb.
Re: Bird cage windsor - corner joints?...
Jack,
What kind of joinery is used in those delicate back corners?
John
I've been waiting for someone to ask that. That corner miter is not a joint. It is carved out of the top piece. The corner is connected with a round tenon on the side piece with a matching mortise on the underside of the top piece.
Brian Holcombe
Jack I recently restored a set of Chinese chairs, all featuring that joint. You can have good confidence in it, the joint held for years with just lacquer keeping it in
Place.
I have friend that has quite a few old chinese pieces in his house. They are put together with some interesting joinery.
