Backyard Amber Varnish
david weaver
I get an error when I try to use the search function to find the varnish thread from a month or three ago.
I did make dammar/pine resin varnish with raw linseed oil, turpentine and maple ash.
This is a cherry guitar neck with that varnish padded on. Looks a little funny because it pads on with some viscosity (it's slightly thinned to rub out).
I'd call it an amber varnish. The recipe didn't yield varnish this dark, but it took me a long time to get the varnish up to the full temperature needed for the oil and resins to properly bond, so it got quite dark in the meantime (it was about 100 degrees short for probably a half hour or hour - don't remember now).
I will probably do that on purpose in the future.
https://i.postimg.cc/Jh0zgMsf/20180929_185633.jpg
Far nicer to use than the canned varnish and doesn't stick to your hands as much. It should go without saying that instead of a petrochemical type smell, it smells like pine resin and turpentine. quite pleasant, but it needs UV to cure unless you want to wait 3 weeks.
Re: Backyard Amber Varnish
Jeremy Osner
Gorgeous!
Search
Search, last I heard, was broken, with no fix on the horizon. It's probably worth saving the address of any thread you think you might want to come back to.
Re: Search
david weaver
I think google would find it, too. I hope ellis doesn't waste any money fixing anything like that on here, because google knows everything about us and every site by now. I just didn't feel like going out to google to find it and make my way back in.
david weaver
Thanks! - the back of the peghead looks almost like it's been coarsely sanded, but that's just the lines in the varnish from padding it on with a cloth. The neck itself has been sanded as a final step to remove any facet and fill pores with linseed oil slurry, but it's still generally crisp.
Telecasters aren't works of art, though, and the work could be a little bit more crisp but it'll be comfortable and cherry guitars are uncommon. Varnished cherry guitars are extremely uncommon.
Steve Voigt
Dave, that finish looks great.
To search this (or any) forum, go to google, type in your search terms, then type site:www.woodcentral.com (or whatever url the forum has). No spaces after “site.” Works much better than any in-house search function.
John in NM
That is really cool stuff David, good for you taking the trouble to make it and learn a few things :D
If I just had some free time, I'd be inspired to follow suit!
Re: Google Search bar is on the Home page
Henry (Raleigh NC)
The search function has been discussed several times on a variety of WC boards. I have read Ellis' posts encouraging the use of the Google search function, and in fact this is now incorporated on the home page, right below Ellis' mug.
http://www.woodcentral.com/
Henry
Backyard Varnish - What was your final process?
Chuck Nickerson
If you don't want to document it (it can be a giant pain) could you point us towards a youtube video that got it correct? There are so many freaking videos...
TIA
Re: Backyard Varnish - What was your final process
david weaver
https://www.youtube.com/watch?v=gh5JTATnl4k
beware of the boil over that can occur when adding the oil to the resins. I asked george about this, because i had to keep removing the pan from the heat to keep it from boiling over. I don't think my burner would ignite it, but it's possible and the way it foams up, I'm sure it would be impressive. (george used the term mushroom cloud for batches he's made that have gotten out of control).
It took me a long time to get the varnish to temp because I didn't want to cover it and let it get out of control. I eventually covered it to get it to 300C because that's the only way my hot plate would do it.
I would advise that as a strategy actually, if you want a dark amber varnish without it being so dark as the pigmented types are (they can look unnatural). I probably had my varnish at 260C for an hour or two where it slowly got to that and stalled, and kept string testing it. It needs that last bit of temperature for the resins and oils to bond properly (or whatever is happening chemically).
It's been a real treat to use.
As an aside, george mentioned that he has mixed the resins and oils together from the start and had good batches from it. I'm not sure if it would still boil over. If not for the fire risk the stink coming off of the oil as it heats (smells like you're cooking something, but it's still smoke from oil that's past the smokepoint, so I'm sure it's not good for anyone). Even so, he said something along the lines of cooking it in a tall narrow cylinder where the cooked amount is only a small volume of the cylinder, so there must still be potential for boilover.
Sorry to be long winded. the final varnish hardens in a couple of weeks if you just let something hang, or it hardens 90% in a matter of hours in the sun, and then can slowly finish over time. It's a pleasure to use - I added about another 75 -100 ml of turpentine after the varnish was finished so that it would be easier to wipe, and even at that, it's still about 30% solids and covers and builds very quickly. I'd anticipate the batch to have made about 20 ounces of varnish, which would easily cover a couple of pieces of furniture, and I'm thinking maybe 10 or so guitars - just guessing. Much less sticky than epifanes when it comes to getting off anything that's accidentally gotten on your hands, and nicer to wipe with because the lack of sticky seems to make it easier to pad onto something.
The suggestion of the space bags makes it really easy to preserve so far - only a tiny bit of varnish at the tip of the bag is exposed to air, so you'd lose a gram or three if anything, and that's it.
