Two rasps I like a lot
Jeremy Osner
One I got recently, it is the large coarse Dragon rasp from StewMac.com, it is awesome. The other, narrower one I got very early in my woodworking hobby, I want to say from Lee Valley or Garrett Wade. It came as half of a pair of rasps, but I've forgotten what the advertised diff was. I don't generally distinguish between them, just pick whichever is handy.
Re: Two rasps I like a lot
Jeremy Osner
I mean, don't distinguish much between the pair of rasps that I've had for a long time, not between that and the Dragon rasp!
(Message Deleted by Poster)
Hank Knight
The narrow one looks like a Nicholson #49 or a #50. They were kind of the standard "good" rasp for years, until the hand stitched ones appeared in the market. The big one looks like it would be perfectly suitable for rasping a dragon!
Jeremy Osner
Huh I bet the pair of rasps is a Nicholson #49 (second cut) and #50 (smooth)... I ought to figure out which is which! :) I will look at the two of them side by side this evening and see what the difference is. Maybe they're even marked!
William Duffield
They are marked. The one in your picture is the 49, the coarser of the two. I have at least two pairs. I used them extensively before I got Auriou rasps (my larger, coarser one is from Lie-Nielsen). I would not buy new Nicholsons, because they moved their manufacturing, but not their expertise, offshore. (In other words, they forgot how to properly make their patternmakers cabinet rasps). Also, Auriou makes left-handed rasps, which work much better for me.
Dragon rasping
The difficult part of rasping dragons, of course, is keeping them from breathing fire at you as you work.
I've got a fine-ish version of that dragon rasp, and can testify that it's a terrific tool. Even with the fine-ish teeth, it removes material quickly, but leaves behind a pretty smooth surface. And the tang is large and blocky enough that I use it without a handle.
Re: Dragon rasping
Jeremy Osner
I just put the handle on a couple of days ago when I happened on an old handle in my toolbox that seemed like a good fit. It seems to give me a little better control of the tool.
Dragon Rasp
Tom Colligan
Jeremy, do you know where the Dragon rasp is made? That is, is it marked on it?
Thx.,
Re: Dragon Rasp
Jeremy Osner
(or not -- I mean I'm guessing that character means "Dragon" in Chinese or Japanese -- but I guess that doesn't have much bearing on where the tool was made... Yep, Google Translate gives 龍 as old-school Chinese character for Lóng, "dragon".)
