shoulder plane cleaning
Carmine
can someone recommend a good solvent to clean hand oil from the steel body of a shoulder plane?
thanks,
Re: shoulder plane cleaning
Can't imagine you need anything special. Soap and water (but dry it off well) or mineral spirits should do it.
I use Simple Green to remove the build up on tablesaw blades and router bits. I imagine that a little would be all that is needed for the grease on a plane body.
brian beebee
For cleaning pitch off saw blades and router bits I find oven cleaner does a great job!
