Lee Valley spokeshave
Jeremy Osner
Hi all, I'm getting back into woodworking after a couple of years not doing any.... Wonder if anyone has encountered this issue with a Lee Valley spokeshave: when I try and shave wood, the blade pops out the back. I tried putting the blade back in and really torquing down on the thumbscrews, but after a few strokes the blade pops out again. Any ideas what I'm doing wrong?
Re: Lee Valley spokeshave
Is this the aluminum bodied black one?
I've had that happen, too, on that shave (the one pictured below). It's not, in my opinion, their best design.
Re: Is this the aluminum bodied black one?
Larry Barrett
I agree, not their best design. Take fine shavings and it will work better.
Jeremy Osner
Yep, that's the one. Thanks, guess I will try adjusting it finer.
Jeremy Osner
It's funny because I've had good experiences with this tool in the past. This is one of my first times picking it back up and I reckon I have forgotten a lot... Also the wood here is hard maple, I think when I've used this tool in the past it was mostly with softer woods.
Rob Lee
Hi Jeremy -
What you are seeing is two finely finished surfaces not having enough friction between then....
If you rough up the mating surfaces with some sandpaper - perpendicular to the movement direction - it will solve the issue you are having....
Cheers -
Rob
Jeremy Osner
Thanks Rob, that sounds like a great idea.
