Varnish Telecaster
Varnish Telecaster
Varnish Telecaster
david weaver
This is the first guitar I've made, I already posted a bunch about it. I've got some cosmetic issues from trying to do things with hand tools that should've been done differently. The only marked issues are the dot on the back of the neck and the attempt in anger to get an angle with a gouge toward the truss rod nut will result in the need to make a custom truss rod cover.
I did buy the electronics, tuners and fingerboard, but I wish I would've made a fingerboard instead. I bought a compound radius board to have as a template and then it warped. It's a boring color - flatsawn maple.
I have done some work on guitars before (fret leveling, etc) so there aren't any playability issues, it plays really well.
Spending the money on high quality pre-wired components and american made pickups makes it sound better than the am. standard fender telecaster that I used to have.
The cherry with varnish makes it look unique, though it'd look better if the body was one piece. So, I ordered a large 10/4 table slab from a mill in ohio to cut future bodies from.
The varnish is epifanes. I think it looks fine, it doesn't have enough build to show a strange hue, and the cherry under it will force an amber color. Still was fun to make the other varnish, and I will switch to it from here on out.
https://s15.postimg.cc/loykdwqhn/20180811_153202.jpg
https://s15.postimg.cc/3ywvsvscb/20180811_153213.jpg
Re: Varnish Telecaster
Wiley Horne—So. Cal.
David,
Big congratulations! Your attention to every detail shows in the final guitar. Thanks for sharing the long journey, which sounds like it’s still in progress!
Wiley
Re: Thanks, Wiley!
david weaver
Yes, certainly an ongoing process. This guitar is sort of a tester, just to find out what parts I'm going to have trouble with working. The great part about a telecaster is that you can make it not so accurately and it'll still be a great playing guitar.
GolfSteve in Calgary
Building a guitar is a very rewarding project. Looks great.
Steven
David Weaver
You're right Steve, it's very satisfying, a lot like making tools is. I can't wait to make another 20 or so and see how much better I can get at it.
Brian Holcombe
Very nice, David! I can say from chair making that transitioning into curved shapes is not easy, especially if you need to sand.
I’ve taken to using a super fine file right up to the last moment, then just knocking out the marks with 320 grit followed by steel wool.
david weaver
100% agree, Brian. I sanded the rout around the outside of this guitar, and ultimately only sanded the neck of the guitar after everything was done. I think I may have sanded a couple of other things on the guitar ahead of time and then had to correct them with scraper and file, anyway.
If there is any sanding beyond that, I lose control of the shape of things (and I don't want to do that). shape is more important than surface finish.
I like plane/spokeshave/drawknife/rasp (whatever is appropriate) for all of the rough shaping, then card scraper/files - just as you. I'd rather follow a coarse file with a finer file than go right to sandpaper - and if sanding is necessary for a look (then I'll sand only as a final step).
I suppose i did this on the fingerboard, too, which is compound radius. I planed it to shape, though, and then only 220 grit sandpaper to remove any facets.
It's clear that there is very little hand work on the manufactured guitars (of course), but their control of getting an even finish is really superb (i'm sure due to narrow responsibility for each person in a process and as warren describes, innovations that push work down to lower skill levels to safe cost).
Mine won't look the same. The proportion of some of the perfectly done (near automated) guitars isn't really that desirable in some cases (the hard edges on a telecaster with low radius, and the really fat neck profiles - one would think that the latter could be changed, but the former would require more complexity).
and the other trend, which has been in place for a while, really thick non-repairable finishes ("polyurethane", which is probably just acrylic, or "acrylic lacquer"). Thick squeaky feeling finishes.
(the guitar on the left is a mexican made telecaster - flawlessly executed except for a few minor things that would be acceptable on a new guitar - like sitaring due to a little tuning needed in the nut slots - but visually perfect. "cherrycaster" is made to a lower finish standard - except the frets and the nut, but the proportions are better and it's more comfortable to play)
Brian Holcombe
It's amazing how perfect they make a guitar body, truly. At this stage it probably has most to do with how much of the process is automated, those things like the transition areas between the neck and body and that of the head and neck are spots that are likely done to near perfection with CNC then blended by sanding.
On my chair I did the same thing, I had to ease a few things where it was just brutal to keep everything extremely crisp. It just becomes and incredible time sink to keep everything sharp to the point that I chose a couple areas to strictly maintain and few that would be better off more easily blended.
When I see their work I see the same thing, they chose a couple spots to keep extra crispy and a couple to relax on. Sometimes the aesthetic of a relaxed transition is very good also.
Truly my favorite tool in the pile is the #4 'precision' swiss made file, its the finest file I have found (Mcmaster sells them) on something I want to keep tight I can work all the way to a finished result, then return with this file and tighten it back up and then just lightly steel wool away the marks and it will be very sharp.
david weaver
100% agree on the process (with the fine files). I haven't tried steel wool yet, but might - presumably it leaves a little bit more of a burnished look than sanding?
In the old days, someone at gibson made the necks on the end of a belt sander (probably something high speed and industrial). Their profile has a bit more refinement than fenders (you can pay high dollars and get fender to make any profile you want, but a $1.4k guitar becomes $3K, and there are no buyers for used custom guitars, so you'd better like it).
I think if I had a full weekend, I could make a very good fender style guitar fret work and all - from rough, without power tools for anything other than the pickup pockets (the market is strange about wanting perfectly clean cavities with no evidence of hand work - makes no difference, but it's not an educated market). Fairly sure if I made a nice profile neck ("custom shop" type profile, which is pretty absurd, they should all be profiled like that) and a tight fit and did great fretwork and then hand varnished the guitars, 90% of the market would complain about the varnish. I've posted pictures elsewhere and someone noted that I "left rough spots on the wood and need to do further finish work to it" (that's actually the surface unevenness of the varnish - it feels divine compared to a glassy surface).
I don't work to your standard, for sure, and on things like plane handles, you can feel that I left them right off the card scraper (I actually like that). I might do the same with a guitar once I've made enough of them, just to see how it feels - you'd never get sticky hands on a guitar neck. That said, I do all of the curved surfaces once and then after a break (next day or hours later or whatever), I look over all of the curves to see if anything catches my eye. I love the fine files for that kind of finish work, whether they're a small saw file or a swiss file. so much more control. Too much sanding, and the surface looks like cellulite legs at the beach, or just bland.
There is some thinking to do about whether or not I can modify some of the details on these guitars to look more like hand work without making a complete abomination (think F-style mandolin - which is the instrument that George complains about the most when I talk to him, a complicated little guitar with lots of sharp edges and tight curves to bind).
Brian Holcombe
The plane handles are perfect, super crispy lines.
I like the finish of #0000 steel wool or super fine scotch bright over sanding. It tends to be similar looking to a high grit paper. I like it especially for chair legs because it is a lot easier to deal with than high grit paper which clogs.
I could see a production shop using a belt sander with a table and a stop, that would make them nicely without more than a few moments effort.
If I had to take a guess, a $1400 finished product is probably allocated about 1.5-2 hrs total work time from rough stock to finished product. I can certainly see how they quickly double when it becomes custom.
