Knew Concepts fret saw
Howard Pollack
Hi- I'd like to purchase a Knew Concepts fret saw, mostly to cut out the waste in dovetails. Does the titanium version provide a significant advantage over the aluminum version? If people have an opinions about this I'd be glad to hear them. Thanks. -Howard
Re: Knew Concepts fret saw
Don Stephan
I think Derek Cohen has compared them.
Thanks Don.
Howard, the titanium is lighter and stiffer for the size. So the size one gets is important. Most consider the 5" model to be ideal, however I have argued for a long time that all you need for dovetails is the 3" aluminium version. Used at 45 degrees, you have a 2" depth of cut, and this is more than you need for dovetails. The shallower frame is lighter and stiffer than the 5" frame, adds the stiffness of a titanium 5", and you safe a bunch of money.
