Apothecary chest - shiplapping the back
When you see shavings like this ...
... you know a skew rebate plane is at work.
Shiplapping is the joining of boards using an overlapped rebate. The advantage of this is to allow for movement while presenting an outward solid and sealed surface.
The rebate is on each, but opposite sides of the board. In this case, I have made the rebate 10mm wide. This will allow for an overlap of about 7-8mm.
Here I have made use of sections of Black Walnut that would otherwise be considered offcuts ...
The boards are 6mm thick, and each rebate is just 3mm high ...
Planing take a few minutes with the Veritas Skew Rabbet plane ...
When the carcass was dovetailed together, allowance was made for a rebate all around the rear of the chest. This required that the area close to the pins was left uncut ...
... which can be seen at the corners ..
The waste was now chiselled out ...
The boards could now be cut to length and fitted. The rebate gap between boards was set with a spacer ...
No glue is used as the boards are free to expand into the gap. A single screw holds them close to the overlap ...
Done ...
And no one will see any of this :\
Re: Apothecary chest - shiplapping the back
clintsearl
A finished back allows a piece to be used and shown in different scenarios. I originally had this buffet sited against a wall, but its shiplapped back lets it become a prominently displayed room divider.
clintsearl
The system is not allowing the uploading of local images.
My sentiments, too, Clint.
William Duffield
That's because you are misspelling your user name. I can tell because it is not shown underlined and blue in your message. We are seeing
clintsearl
Maybe you need a space?
Clint Searl
Here's the sideboard example
Clint Searl
Don Stephan
To dress up the back even more, consider a small scratch bead along each edge.
Don, a bead is too much, really. :) There is so much more to do, and I am running out of time. What I have done - and this does clean up the back to my eye (but then who is going to know this anyway!?) - is the drill the holes a little deeper and clock them ... Rob Lee jokingly said they should be clocked with the grooves vertical (so the dust falls through :D ). So I've done this! I'll post a picture later on.
clocking
As requested by a number of people, I have clocked the screws at the rear of cabinet. Gad, some are so OCD! :D
One coat of oil so far ..
Brian Holcombe
That's a nice looking back. I don't mind the screws, clocked or otherwise and taking movement into consideration is a nice feature.
If I may :D I am honestly thinking that stopped rabbets are both a time consuming venture and offer a nice extra bit of short grain at the end of them that becomes a liability.
I'm not sure if you had the room, but a softwood strip running along the inside edge would give a nice hold for screws (smaller ones) and improve the look of the finished back while being easier still to create.
I like to make things complex, but often I'm attempting to make a simple result so I'm looking for ways like this to keep the simple things simple.
Hi Brian
I agree with your comments. In my defence, I did not think this through early on, and then ran out of time. :\
