Using Spyderco stones
Howard Pollack
I've recently purchased a pair of lightly used and lapped Medium and Ultra Fine Spyderco stones. Do folks use them dry? If so, what happens to the swarf? If not, what is the best lubricant. Thanks.
-Howard
Re: Using Spyderco stones
bridger
Bridger
I spritz a little isopropyl alcohol on them, but almost anything will work.
Ron in Sterling, CT
I agree with Bridger. I spritz a little water on them while using. When they get real dirty, I wash them with warm soap and water.'
Ron
Howard, I spritz with a little soapy water. This keeps the stones clean as well as washing the swarf away. I know that Spyderco state the stones may be used dry, but this will eventually clog them.
Howard Pollack
Thanks to everyone. I think I understand how to best use the stones.
-Howard
Barney Markunas
Bridger, I'm curious how you settled on isopropyl alcohol. Seems to me like something that doesn't evaporate so easily would be a more convenient choice.
bridger
Bridger
Having a spray bottle of alcohol in the shop is useful for other things. It's a good cleaner and it evaporates completely. I don't have a sink in my shop so water stones are a bit of a hassle. Isopropyl is available in various strengths from many pharmacies and department stores. The bottles have thread caps that fit readily available spray caps. The 90% stuff does evaporate too fast for my use- 70% is about right but if that's still too fast for you try the 50% stuff.
Even at 50% it flashes off completely carrying the other 50% (water) with it, so rust isn't a problem. The residue left on the stone is a dry powder which wipes right off. Unless the stone is very coarse al. Oxide in which you'll probably want oil anyway, the super thin liquid gives very good feel to the stone.
If you share your shop with a furnace or waterheater or anything else with a pilot light or you smoke having a spray bottle of alcohol around might not be a great idea.
