Spoke shave jammings
Philip Duffy
I have a handful of spoke shaves, including one I built from a kit, one by a noted maker, and a couple of Stanley's. Then, there is my one and only one that never clogs up and it cuts like a razor all the time. I have no idea who made it but it must be old. The handle is a round steel, bent into a long loop for the handles. That baby is so wonderful I am afraid to take it apart to sharpen the blade. All the others jam with shavings at the throat. Should I just file/sand the throat to open them up? There must be a right way and location. All help accepted with cheers! Phil
Re: Spoke shave jammings
Got a feeler gauge?
If you've got a feeler gauge, check across the width of the mouth, with the iron installed and in cutting position. I've noticed that, on a couple of my Stanley shaves, the front of the sole has warped or been pushed back over time, so that the opening is narrower in the middle than at the edges. If you find the same, it would be worth filing the mouth so that the opening is equal all the way across. Use a fine-toothed file, and aim for a smooth finish.
William Duffield
If the one you have "by a noted maker" is a Lie-Nielsen designed by Brian Boggs, it is designed as a finish tool, with an intentionally very tight mouth to minimize tearout on highly figured woods. It works beautifully for its intended purpose, but it is not designed for heavy stock removal. Use one of your other shaves for hogging off, and adjust the L-N blade to take a very thin shaving for final surface smoothing. Do not ruin it by filing the mouth open.
Philip Duffy
Thanks to Bill and Wm for the responses. Both are very valuable advise and I will apply them to the shaves and they Will Be improved- - or suffer banishment!! P.
Jack Guzman from Maine
Phillip,
I find that when I get that problem with a shave it's usually because I am trying to take too big a bite. Try it with the blade backed up a bit or turn the shave so the blade isn't digging in so far. You do this by riding on the body of the shave and turn it til the blade just starts cutting. This all depends on the style of shave you use and what you're trying to cut. ---Jack
Philip Duffy
Thanks again, Jack. One of these days when I visit my sis in Gorham I will swing bye your shop and see how you adjust. I did find a major defect in the Lingamvia insert in my one shave so I got that straightened out. Tks again. P.
Any time
I love getting visitors to my shop even though it's almost always a mess.
"...even though it's almost always a mess."
Proving you're doing actual work in it.
bridger
Re: "...even though it's almost always a mess."
Bridger
I've seen your shop, Bill. It was a mess.😁
So's mine, most of the time.
