Paean to the double square
For a long time, I didn't know why people would buy double squares instead of combination squares. After all, a combination square gave you a 45 degree miter square, too. But then I acquired two (4" and 6") at yard sales, and now I know.
First, the stock (handle) on a double square, at least in the 6" size, tends to be longer than that on a combo square, giving you more registration against the edge.
Second, I often find myself, in the sorts of work I do, marking off holes a set distance apart at consistent short distances from the edge, for driving screws to, say, hold a panel in place (we're not talking foine woodwork here). With a double square, I can set the beam (rule) to the distance-from-edge and use a long rule or tape measure to make tick marks at the distances along the edge, from screw to screw. With the double square, I can then strike a line at the tick mark to bring it to the edge, flip the square around, and mark the distance from the edge; and I've got crosshairs showing me where to drill the holes for screws.
Now that I own them, I wouldn't be without them.
Re: Paean to the double square
Agree, and a mystery
Wiley Horne--So. Calif.
Bill,
I could not agree more, and have forgotten all the reasons why.
Mystery: Did Starrett ever begin making a 6” double square with satin chrome blade? They do put satin chrome finish on their combination squares and rules, and I have a Starrett 4” double square (I think from Joel) with chromed blade. But not the 6”—did they ever change their mind?
Wiley
bridger
Bridger
The only down side I've encountered is when the sliding head is set to somewhere near the center of the blade it isn't obvious to the hand which end to mark from.
William Duffield
That's one reason I have both a 4" and a 6" double square at hand all the time. If the setting is too close to the the center of one of them, I just use the other one instead.
https://www.harryepstein.com/index.php/pec-4-double-square-16r-7104-164.html
https://www.harryepstein.com/index.php/6-double-square-16r-usa.html
Can't beat them for price, accuracy and visibility of ruling. (BTW, they carry them in metric, too.)
