Re: lengthwise bookmatching
TomD
If you want to join panels end to end, you could just biscuit them with epoxy, would be plenty strong enough for most panels, if not wanted in this case.
It is something of a misconception that endgrain glue joints are weak. I wouldn't be surprised if they were stronger than butt joints in sidegrain. The issue is that longitudinal strength in boards is great, while crossgrain strength in boards is weak. So you need a far stronger joint than a sidegrain joint in order to get full strength joining boards end to end. But that is not the same as saying that those endgrain joints are weak in comparison to sidegrain joints.
Laying out a 4 way bookmatch would ideally find you in possession of a board with very little riff grain, so that the pattern projects through the panel far enough to get your pieces out. Or that you otherwise get some kind of pattern you like.
Veneer should be advantageous in a seaside situation. Plywood would be the ideal panel material. Pretty much for any use, but certainly by, or even in, the sea. An extra layer of veneer over the plywood is not going to make maters any worse. And veneer is also ideal for preserving the pattern through multiple layers. That said, I can certainly understand a preference for working in solid wood, even though veneer is just as traditional.
Another option with veneer is Krenov's "real veneer" approach. Basically you saw heavy slices of the donor board, and bond them to a solid core. You essentially create a board that has all the appearance of the donor, board. And a board that can be worked with planes, or other hand tools just like a piece of solid wood, though you have to hide the endgrain.
