Any spokeshaves that work with one hand?
Denny
I sometimes find that I'm hanging on to a project with one hand and trying to do some final shaping with the other hand. I've had some success working the Lee Valley low angle shave with one hand, not much success with the standard size Lee Valley shaves. Is there anything in current production that would be easier to handle with one hand? Flat bottom is what I'm looking for.
Thanks,
Denny
Re: Any spokeshaves that work with one hand?
AlanWS
I don't find the Stanley ones work well one-handed, or ones with turned handles. Traditional style wooden spokeshaves with blades mounted using two tangs into a stock that's a single piece of wood seem best one handed.
This allows you to whittle with effectively a cut-depth-limited pocket knife. But it can't compare in terms of either speed or accuracy to a spokeshave used with two hands on a shaving horse.
Re: Maybe these?
Denny
Thanks, those look like they could work, but they're listed as "currently unavailable." I might give them a call in the morning.
Denny
Alan, do you know who might make something like you've described? I know I could make my own, but at the moment I'm more inclined to put my energy into making furniture rather than tools.
Re: Maybe these? *LINK*
Denny, I doubt they would work, so save your money - spokeshave, no matter the size, still require being balanced, and their narrow sole will skew if more pressure is placed on one side than the other. It would be very difficult to balance these with one hand, even if they appear small (I have one).
The tool that I recommend - and I know that this works as you seek - is a scraper I built based on the Stewmac scraper for guitar building (link below).
Mine is the rear end of a 1/8" thick O1 plane blade that I shaped ...
This is prepared very simply by grinding the edge to a burr on a bench grinder ...
The finish is actually pretty good ...
Stewmac scraper
Jack Guzman from Maine
Thumb Plane
Denny,I have alot of spokeshaves. All different sizes and shapes. I sometimes use one one handed but it is an awkward process. I know of no shave that would make this easier. Do you use any thumb planes? I have several that fit right in the palm of my hand and are great for one handed detail work. I'm talking about planes similar to the stanley 100 or 101.---Jack
This looks like a great idea!
Denny
Thanks Derek, I'll try this.
Denny
Re: Thumb Plane
Denny
Thanks Jack, I don't use any planes that small, I'll check it out. It looks like Lee Valley has a variety of mini planes that could work.
Denny
Another thought
Carvers often do insanely clean and precise work with chisels. Have you considered a knife? Look for "hooked," "bent," or "curved" knives online.
Re: Another thought
Denny
Bill, that's an interesting idea. I'm sure I've got an appropriate knife hiding in a drawer somewhere, I'll try it out.
Thanks!
one handed carving knives
Ian Neuhaus
Our favourite candy store has these -- Pattern A is probably the best for final shaping.
Although these knives come with hardware, you will need to source and shape your own handle.
Link http://www.leevalley.com/us/wood/page.aspx?cat=1,130,43332,43339&p=43352
Re: Another thought
Denny
Well I gave it a try with a knife, but I had to stop or else I wouldn't be able to count to 10 any more...
This works well
Denny
I sacrificed a plane blade and now I have a fantastic one-handed scraper.
Re: one handed carving knives
Denny
If I use one of these I probably will be one-handed very quickly. I normally think of myself as fairly well coordinated, but a man's got to know his limitations...
AlanWS
There are a lot of old wooden shaves around. You are right that the new ones like this tend to be kits, but MWTCA meets (where I got mine), or reputable used tool dealers would likely have them.
Philip Duffy
a Very Long time ago I learned (down on the farm) to fit ax handles by breaking a window pane of glass and using a straight and very sharp edge to bring the new handle into submission. It cost Zero and it still works today.
Denny
That's a good idea. In fact, people also use glass knives for cutting thin sections for electron microscopy, but I think Derek's plane blade/scraper will do the trick.
bridger
Bridger
Something like this?
https://www.woodcraft.com/products/carvers-spoon-plane
I have similar but push cut. I don't know where to buy them, they were my dad's
Denny
That's an interesting idea, but I'd rather work with something with a flat sole. Working with Derek's idea of a scraper made from a plane blade is pretty good, but I find it not as fast as a spokeshave. Hopefully this project will be past the shaping stage soon and I can post some photos.
Denny
