round bottom spokeshave recommendation, please
Howard Pollack
Hi- I'm looking for a spokeshave to work inside curves. I wonder if folks have recommendations? Thanks.
-Howard
Howard Pollack
-Howard
Re: round bottom spokeshave recommendation, please
Jack Guzman from Maine
Lee valley has a nice wood handled version,Veritas. It is a fine tool for the job. My favorite however is the Boggs designed brass shave sold by Lie Nielsen.---Jack
It really depends on the curve. Most flat bottom metal shaves can plane inside a "moderate" curve. It depends on the width of the sole. I like the LN Boggs shaves for their balance, and the round bottomed shave can plane a tightish curve. If you want to get into really tight curves, then you need something even smaller. LN make one. I have the Preston copy from Veritas.
Bruce, a MN Galoot
I have the Boggs, too, and really like it. I’m not able to tell what radius would be the inside limit.
If you can hold one in your hands, it will help. My one concern about round-bottomed spokeshaves with adjusting nuts is that the nuts can interfere with the curve. I owned a Record clone of a Stanley 151 for a while, but released it into the wild when I realized that the nuts were getting in the way - and this was a flat-soled shave. I now own solely shaves without adjusting nuts. It's a little trickier to set depth, but it can be learned fairly quickly, and the handling is much better.
As far as vintage tools, I kind of like the Stanley 63X I picked up at a yard sale: really tight mouth, pretty tight curve. I should emphasize, though, that my example may or may not be representative. This shave was sold as a manual training (shop class) tool, and it's possible that the tight mouth on my copy was an accident; other copies may be sloppier.
If the curves are really tight, you might look at a "cigar" shave, like the one Woodjoy Tools sells (http://www.woodjoytools.com/spokeshaves/brass-circular-shave), or the original design by Millers Falls (much cheaper on Those Auction Sites than the Woodjoy, though with the usual issues of used tools).
Wiley Horne--So. Calif.
Hi Howard,
If perchance you find yourself searching for a really tight-radius shave, I suggest using rasps and files instead. I tried it both ways, using a tight Preston as well as the LN small bronze shave, and a custom LN shave that Thomas LN ground down to the tightest radius possible. In my hands, rasps and files were much better than the shaves, for one thing, in a tight curve you’ll be working end grain.
Wiley
Brian Holcombe
I agree, use a shave for larger inside curves, and very tight curves a file or rasp. 00 files produce a very good finish.
Thanks to everyone
