a hard groove to plough
justin ball
Car boot sale find....a very generic 2 quid plough plane.
However, the skate is not level, a degree of dihedral.
How best to correct? Bench sander?
justin ball
Re: a hard groove to plough
John Aniano in Central NJ
Justin,
If the skate isn't flat, you could file it as well as use a belt sander. I've never seen one where the skate was hardened. Just be careful if using the latter method and not take off too much or discolor the steel by overheating!
I know that you didn't ask about this, but...
If the skate is not straight, side to side, that is much harder to correct if it is really bad. Skates get un-straight usually because the wood stock warps over time. Usually, a small amount of non-straightness can be tolerated. Best to try the plane and see if it's a problem.
John
justin ball
It's a problem. It rocks fore and aft and the iron bites too much or not at all. It's straight, and it's brass, not iron, adjustments by loose wedges. It's going to have a ride on the bench belt sander with a disposable fine belt.
Steve Voigt
The skate usually fits in a groove in the plane itself, and the groove helps keep the two parts of the skate parallel. If you belt sand it, it will no longer be a tight fit. I would remove the skate and flatten it with a hammer. I've done that succesfully.
If you've already sanded it and the sloppiness becomes a problem, get some brass shim stock to take up the slack.
david weaver
I wonder if some of this was built into plow planes. I don't know, just wonder.
I've gotten three or four wooden plow planes, and have had to make the same correction each time. Some more correction than others, but it's always the rear skate that's low.
This is your plane, so do what you need to do to make it work. Wholesale refurbishment of the joining area where the skate meets the body is OK, as is actually making a new skate if it's damaged (but I've never had to do either of those).
David, et. al.,
I've noticed the same thing. Always just assumed the rear skate was usually lower because the groove of the blade is pressed into it (it is, after all, the lower portion of the bed for this type of plane) and over time, the skate gets pushed below the front skate.
I've observed that skates are held to the wooden stock by three methods - countersunk slotted screws, countersunk screws with the slots filed away and more or less riveted pins that might have begun life as a threaded screw shank. There may be more methods, just what I've seen. The first can be easy to remove - just keep note of which screw goes in which hole. The latter other methods would be hard to take apart - I've never even really tried. I'd be curious as how others might have removed a skate that was held by the latter methods.
John
david weaver
I think for the latter types, you'd probably have to destroy the skate and use something else. I'd opt for brass slotted screws, but those aren't always easy to find. Or older steel screws that look good (the screws in transitionals come to mind, but they have to be the right size).
If the plane is a really nice one, this kind of thing is off the table. If it's a $40 plow plane that's intended to do brute force work, then no problem.
I wonder if the skate is low on a lot of these and was from the start because they were intended for heavy repetitive work with a cut depth that would be at least the skate differential. Perhaps there is something to that geometry that causes a bias in the cut so that ends don't get planed low.
Whatever the case, if it doesn't suit a current user, it needs to be fixed, and I've fixed mine.
