Pull Saw Stand *LINK*
Kevin French
My new pull saw stand made from wine heads and a white wine stave
Pull Saw Stand
Re: Pull Saw Stand *LINK*
Re: Pull Saw Stand
Don Orr
Very cool ! Cheers!
The curved stave turns it into
Wiley Horne--So. Calif.
art. Makes you wonder what else can be made from those. Derek’s Stool 2.0?
Thanks for sharing!
Wiley
Re: Pull Saw Stand
Patrick Chase
Nice stand!
It's a pity that the saws all cut the wrong way, though :-)
(FWIW I have several Japanese saws for various uses. I just prefer push saws for purely subjective reasons and because that's what I learned with).
Re: Pull Saw Stand
Kevin French
I like to push things also and have several Western saws. But I also like these pull saws working with the oak.
Tease: The Double Layer Saw Till using staves is my next project.
P. S.
Can we see one of your chairs?
Wiley
Wine barrel furniture and the like
There's quite a bit of it around here - lots of old wine barrels in wine country.
People often make references in their designs to Japanese furniture and temple conventions, something made easy by the curves in the length of the staves.
(Message Deleted by Poster)
Re: P. S. *LINK*
Kevin French
Here is a pic of the chairs. Also the small pieces on the right side of the pic, up and down are ones that I made along with the hoops.
I'm the R&D guy of small things
http://https://lh3.googleusercontent.com/vRIsqyJ8Uf9jXyEwzQkzxw-nUMFdufB6P_JDmzQfhtUS7NJNm2t9VnMfEgvHJKO0sYizaGzAdpGq7iDWiXQ2cGyU4wD_DwgT7x3__3DtxlOJBVPw2NQle1LQMK9KWrgCvrKS--piHX5okVMiTH3gN5FztgD9gSjCJY7eDLL9dTPPxE-Y055nfsZLhyLsRVyocGeDCK_ezGSeseN5s
Re: P. S.
Bruce, a MN Galoot
When you paste the link, please remember to take out the http:\\ that is already there.
Re: Wine barrel furniture and the like
This area's had a small but mighty cooperage operation going for a long time. Our son has a friend whose father was trained as a traditional cooper, and worked as a cooper.
Kevin French
Barrel Staves are a lot of fun to work with. There isn't a square part on then except the ends are parallel . Staves from the same barrel may not have the same curve, all that makes for a big learning curve.
The first time I had to cut the ends off a stave I felt like a 10 year old again in 4H woodworking class, trying to figure out how to cut them square.
