Hide Glue??
Hide Glue??
Hide Glue??
Tom Norton
On a recent post I ask about glue and wedge tenons. I think I will do a few mock ups to try it out.
Regarding hide glue. I understand that there is a shelf life on the ready mix kind like Fanklin brand. I was just at the hardware store and looking at the bottle. No date stamp just some type of code.
So....?
Thoughts?
Re: Hide Glue??
Jack Guzman from Maine
Re: Hide Glue??
I use Patrick Edward's old brown glue. "toolsforworkingwood" sells it,as do other online vendors. Liquid hide glue does have a shelf life. My experience with Franklins the glue usually has an expiration date. I have used old past dated franklin and it worked fine. Patricks was developed by Patrick Edwards for his own use in marquetry. His glue is always marked with an expiration date. I just prefer it over the franklins.---Jack
Re: Hide Glue??
Re: Hide Glue??
William Duffield
Like Jack, I have used both, and definitely prefer Patrick Edwards' OBG, which you can also buy directly from Patrick. The expiration date is only a general guideline. LHG will definitely go bad, but the details depend more on storage temperatures than the date on the bottle. I keep it refrigerated and decant it into small bottles. I usually use the 4 oz. FastCap BabeBot
https://www.fastcap.com/estore/pc/viewPrd.asp?idproduct=57367
or a Monoject 412 syringe for very small jobs.
You need to bring it up to around body temperature to use it, so a small bottle that fits in a shirt pocket is convenient. Overheating it can shorten the shelf life, and if you get it much over 150°F, you cook it, making it totally useless, so use a glue pot, not your microwave oven.
To find out if it has spoiled, do a pinch test. Place a drop between the tip of your thumb and index finger and rapidly tap them together and spread them. After several taps, if the glue is good, many fine tendrils or threads should form between your fingers. If not, toss it out or give it to your bench dog. If he rolls in it instead of lapping it up, it's definitely past its "use by" date.
Re: Hide Glue??
Old Brown Glue link
Wiley Horne--So. Calif.
Talk to the nice lady who answers the phone :) . They ship fast, and you’re buying from the latest batch:
http://www.oldbrownglue.com
Wiley
Re: Hide Glue??
“Talk to the nice lady who answers the phone”
Bruce, a MN Galoot
She is the absolute best!
Re: Hide Glue??
Re: Hide Glue??
Brian Holcombe
Nice thing about OBG is that the joint does not seize when your assembling. I've never previously had this happen until very recently using Titebond III on a critical part with a lot of glue surface. I very much kicked myself for not using hide glue. It's not normally an issue if you can pull a part together with a clamp, but you can't always do that when building chairs, at least not all that easily.
I use both hide and modern glues, each for different applications. The downside to liquid hide is that you need to keep the part clamped for 24 hours. I do find this to be annoying as I like to be able to remove clamps after a few hours and move onto the next part of an assembly.
Re: Hide Glue??
I like dry hide glue... *LINK*
John in NM
No worries about shelf life (at least not in the arid southwest).
I have a 1 1/2" copper pipe cap for a glue pot, and a coffee warmer to heat it, works great for small assembly steps that require gluing only 2-4 joints at a time.
Lee Valley came up with a similar setup, that I bought just because it was cool (see link).
http://www.leevalley.com/us/Wood/page.aspx?p=74043&cat=1,110,42965&ap=1
Re: Hide Glue??
Re: Hide Glue??
John Aniano in Central NJ
Tom,
A typical Titebond (Franklin) hide glue code looks like:
"A606210011"
And is decoded thus:
"A" means made in America
"6" is the last digit of the year it was made, 2016
"06" means the month it was made, in this case, June
"21" is the day it was made, June 21
"0011". I have no idea what this means...
The Titebond rep told me the above info. When I asked what the shelf life was, I was told two years from the date of manufacture, so in the case above, would be good until June 2018
John
Re: Hide Glue??
Re: Hide Glue??
Tom Norton
Thanks for the replies! I will be going with the OBG.
Re: Hide Glue??
Titebond FAQ list from their website....
Brian Roberts
http://www.titebond.com/frequently_asked_questions.aspx
From that list:
How Do I Read The Lot Numbers?
Our current lot numbering system is a 10 digit code.
The format is: aymmddbat#. The "a" stands for Made in the U.S.A. The "y" is the last digit of the year of manufacture. Digits "mm" represent the month, and "dd" represent the day of the month. The final four digits represent the batch number used for quality control purposes. Therefore, a product with the lot number A104270023 was manufactured on April 27, 2011.
Re: Hide Glue??
The 0011 is .....
Brian Roberts
simply a lot number.
