Sharpening Japanese Handsaws
DP
Can someone recommend a place that can sharpen Japanese handsaws? Thanks.
DP
Re: Sharpening Japanese Handsaws
david weaver
Who is or who are the makers of your saws?
I don't know if anyone in the US is doing this for "nice" saws.
DP
I don't know the maker. The saw belongs to my son and I suspect that it was not an expensive one.
david weaver
If the teeth are black (impulse hardened) then he can carefully touch up the facets on them with a diamond japanese saw file, or perhaps a card file on some parts and improve the performance. Otherwise, those are generally intended to be replaced rather than resharpened.
If it is a high quality saw with a hardened sawplate and similar teeth, they're usually sent back to japan to be sharpened and checked over (not cheap, and takes a while).
Brian Holcombe
I haven’t used Mark’s services but you might try Mark Grable.
Patrick Chase
Building on something David alluded to: Inexpensive Japanese saws almost always have impulse-hardened teeth, and realistically can't be sharpened by anything but diamond or CBN. As he says the most you can realistically do is touch one up with a feather-edge diamond hone.
Howard Pollack
I used Mark many years ago. He did a fine job, but I'm not sure he is doing this any longer.
-Howard
DP
Thanks to everyone for your input. I'll pass it on to my son.
