Tormek+ CBN wheel
Tormek+ CBN wheel
Tormek+ CBN wheel
Wiley Horne--So. Calif.
Hi all,
Anyone here tried a CBN 10” wheel on a Tormek? If so, what grit have you tried, and what would you recommend. My interest is in restoring the hollow when the flats get kinda fat, on both O1 and alloy steel. I would hone on water stones (natural and Sigma) after the CBN wheel.
Thanks,
Wiley
Re: Tormek+ CBN wheel
Hi Wiley
I only used (use) my Tormek as a grinder, and not as a sharpening system for plane and bench chisel blades. Consequently, the wheel was left at the 220 grit setting, which is the coarsest. There is not much heat generated at the slow speed, and the water was - I believe - really about keeping dust down. If I was to add a CBN replacement, I would go for something close to the same grit, or a little coarser for speed, say 180 grit.
I've got a CBN on my Tormek.
Chuck Nickerson
I put it on because it removes material faster and I don't need the water bath.
I'm glad I did it, but then I used to spend fairly freely on tools.
It's either 80, 120, or 180. Whoever made in doesn't mark the grit on the wheel.
Hindsight being 20/20, I should have written the grit with a felt pen.
Tormek Speed
david weaver
I had two tormeks in the past - well, one knock-off sheppach and one tormek. I gave the tormek to George Wilson because he had a jet version that turned out to be junk.
I always thought it would be a wonderful device if it could spin three times as fast. It can't because of the water - you'll be wearing it.
I wonder if there would be a way to step up the speed easily, even double or so, with the setup that tormek has. It's been years since I had mine, so I'm having trouble visualizing the coupling from the motor to the drive wheel on the left side.
A double speed tormek with a cbn wheel would be really nice.
Re: Tormek Speed
Better than that, I have a half-speed 8" bench grinder with CBN wheels that uses (on one side) the Tormek blade guides. On the other it has a flat tool rest.
The Tormek guides are great for precision grinding, while the flat tool rest allows for freehand work.
Re: Tormek Speed
david weaver
I agree - I prefer a grinder. Enough so that I gave away a $350 used supergrind - I'd had it, but recognize that's just preference.
There are lots of folks who already have a tormek, who like the fact that not much flies off of it, and I figured if I'd have kept mine, it'd be a lot nicer to use if it went twice as fast....but then the water, etc. I have a shop area that is tolerant of dust...makes my grass trimmer a little gritty at the bottom, but that's it.
I never asked george if he actually uses it, because that sounds like checking up on someone (and I wouldn't care if he never did - it's off my bench and someone else's issue now). I know he has an old flat face craftsman grinder that he likes (i like them, too - they have a lot of clearance on the inside of the wheel that a barrel shaped motor housing doesn't.
As I've improved with a dry grinder
Chuck Nickerson
I still use my Tormek/CBN for rehabbing the convex side of carving gouges.
I'll look at the drive mechanism tonight. It would be fun to double the RPMs.
Perhaps a jury-rigged Reeves drive is in order...
Re: Tormek Speed
Patrick Chase
The Tormek uses "friction gearing". There is a rubber-rimmed drive wheel mounted to the motor (parts 4 and 11 respectively here: https://www.fine-tools.com/Tormek-Ersatzteile.html), that spin the shaft with the arbors (part 10). The shaft is part of a fairly complex assembly.
To change the rotation speed you'd need to either find a compatible higher-RPM replacement motor, or you'd need to use a slightly larger drive wheel and a smaller shaft to change the drive ratio. The shaft has a bunch of other features on it, so creating a compatible replacement would probably be a pretty significant machining project.
Note also that the Tormek's motor is only 200W (~1/4 hp). It has more than enough torque for its default speed, but not a lot of headroom for longer gearing.
Re: Tormek honing wheel
Josko Catipovic
With apologies for thread drift, I've never been able to do much with the Tormek honing wheel. Has anyone successfully mounted a grinding wheel on that side, perhaps a finer grit than the original. There seems to be no way to mount a water trough there.
Failing that, I'd welcome any advice on honing WW tools on the Tormek honing wheel vs on fine waterstones.
Patrick Chase
I've successfully used the Tormek leather wheels including the smaller profiled ones that they sell for carving tools. It's basically the same (and has the same tradeoffs) as any other powered polisher
Admittedly going from that 220# main wheel to the leather polishing wheel is quite a step, and requires much more time on the leather than I prefer. Some people (Pete Taran for example) seem to work around that by getting a second grinder with the 4000# "Japanese Waterstone" wheel, but that just seems excessive to me.
Mark Trenier
I have one for one simple reason--it's the same cost last the regular wheel. It will last a whole lot longer too. I use mine and I could not be happier. perhaps it's because I do not let my tools get too dull, but I don't find much difference in time between the former and a grinder. Just my two cents.
Thanks Mark. Which wheel do you have? And if you had it to do over, would you get the same one?
Thanks,
Wiley
Re: Tormek Speed
david weaver
There are definitely limitations, but I think you could double the speed and reasonably get away with it (as long as you didn't want to use too much pressure). I was thinking some real high brow solution, you know, like widening the channel the drive pin fits in on the plastic wheel and putting wire shrink around it to make the diameter bigger.
At some point, now I recall, I got autosol in that channel on my wheel and the otherwise favorable ratio set up to run the wheel slowly lost all of its traction.
Who knows if modification would bear any fruit. Maybe the reduction in pressure that the drive system would be able to handle would negate the increase in speed.
RK
Mine has 600 grit cbn wheel. Seems to be fast enough and works well with carving tools. I lightly oil the wheel to keep dust minimal. I had to remove plastic basin because cbn wheel was rubbing against it.
Thank you for info!
