Planing Plywood
Re: Planing Plywood
Re: Planing Plywood
Patrick Chase
Depends on the ply.
The high-quality "multi-ply" ones typically have 1/32" face veneers, so they plane quite well. They're no more or less difficult than a glued-up top, and often better depending on how the veneers are matched on the show face. Of course that stuff isn't cheap. I think I paid a bit over $100 per 4x8 sheet of 3/4" multi-ply Maple at my local dealer (MacBeath in Berkeley).
The more common "veneer core" stuff is all over the place, with some of the cheaper examples having paper-thin face veneers and relatively soft core veneers underneath. They're more difficult to plane both because you don't have much margin for error, and because the more "springy" (softwood or poplar) core underneath gives the surface somewhat unusual and tricky stiffness properties.
Re: Planing Plywood
Re: Planing Plywood and dovetails
TomD
I've planed tons of plywood as it is the stuff of boatbuilding. Face planing does give me flashbacks to when I planed up the surface of a teak table very early in my woodworking career. Sometimes the veneer will just detach, which is another good reason to use a breaker on that stuff. I have to say that when I pay for veneer faced solid ply I don't particularly like to have to do much finishing, that is the purpose of buying ply, but I am not immune to stains and all that, and some of my projects drag on where the whole project needs a bit of a refresh.
I also like cutting dovetails in ply. One might think that one wouldn't get a good bond, due to end grain. But you get a better bond in the butts, and a tolerable bond everywhere else. The thing is that it isn't so much that endgrain doesn't glue well, it is that loads on an endgrain joint can be higher than on a sidegrain joint since sidegrain splits. When one is making a box, the dovetails don't function as scarf joints, yielding 100% structural continuity, they are just dang strong for what most of our boxes need done, and that pretty much applies to dovetails in plywood boxes also.
