Actual Projects
Actual Projects
Actual Projects
david weaver
A project that's not ever gotten as high priority as it should have is me finishing my kitchen cabinets. There are a lot of reasons for that, but most of them have to do with indifference and conflict avoidance (and making a relatively labor intensive design that relies on dadoes and all solid wood for doors, panels, etc).
I'm finally on the very last one, and it's one of the oddball corner cabinets that's got a face frame that's 45 degrees from those on either side of it. I've got few accurate machines (though I do have a decent router table, to be ditched after this is done).
So this whole thing is hand work, and since it's the last one, that includes the plywood. I'll bet it took me two hours to make the face frame, bevel the sides to 45 degrees by hand, decide how to cut the grooves and lay it out (plow plane, free hand and rabbet and moving fillister for the side of the groove and to notch the plywood, respectively).
Special open toe shop shoes included - keeps it interesting at the bench.
I'm sure some of you guys who do kitchen work have made a gaggle of these cabinets, but they're sort of a pain with crappy machine tools and no layout software. I think it may have been easier for the case to just make a square and then cut the corners off until I had the right span to fit in the grooves of the face frame. Any thoughts?
I've built a couple of non-kitchen cabinet things during this time (aside from about 25 planes), but it still feels like the end of a project, and I sort of resent when the projects are finished!
(Of course, I'm making another plane right now, too - and two other infills that I don't have in the picture)
The planes are interesting enough to make from start to finish with no interruption. The cabinets, not so much.
Re: Actual Projects
Re: Actual Projects
Brian Holcombe
David,
Great thread, I'm sure your wife is glad to see the kitchen cabinets on their way. I've been making kitchen cabinets as well and mainly using hand tools but I've deviated significantly from the typical face-frame construction for that purpose. It's a highly labor intensive job when you are not using machines.
Here is some other stuff I've done recently, or, better said...currently doing as neither of these are actually finished. I have to work out the trim around this cabinet and cut the aluminum back a bit so that I can actually close the doors.
On this I need to make something for that panel. I whipped up a shoji for the Japanese TV crew and decided to use it to make the shop a little nicer so on the weekends I put together a quick 'timber' frame using DF 4x4's of the highest quality that I could find at the big box.
Re: Actual Projects
Re: Actual Projects
Patrick Chase
Wait, the crew that came to film you making Shoji was from *Japan*?
You're internationally famous!
Re: Actual Projects
Re: Actual Projects
david weaver
Looks great! I know the pictures from a distance don't do the quality of the joinery justice.
Re: Actual Projects
Re: Actual Projects
Brian Holcombe
They are from Japan, the premise of the show is that they're meeting people who want to visit Japan and practice traditional Japanese crafts without having trained in Japan or visited. So, they have to hunt down people like myself.
It was a lot of fun, but quite exhausting as I made that one in a couple of nights.
BTW, keep an eye out for some AYC it should be arriving soon.
Re: Actual Projects
Re: Actual Projects
Brian Holcombe
Thanks David!
Since it is tightly bound in that frame I actually left it without glue in any of the joints. I'm curious to see how it behaves over time.
Re: Actual Projects
Re: Actual Projects
steve voigt
Dave,
Good idea. Actual projects are a great cure for all the silly stuff. Congrats on finishing the cabinets! Looking forward to seeing an installed pic.
And Brian, awesome work, and congrats on the video segment! You're an international star!
Anyway, here's my contribution, a jack I just finished up. Going in the post tomorrow. Enjoy.
Re: Actual Projects
Re: Actual Projects
Brian Holcombe
Thanks Steve! Nice plane!
Re: Actual Projects
Re: Actual Projects
david weaver
Very nice. I hope it goes to someone who just completely wears it out. Or tries to. :)
Re: Actual Projects
Re: Actual Projects
Gary B.
how about this one? Not too fancy, but it does the job.
