through mortise, drawboring advide
Gary B.
I've got 10 or so saws in need of filing. So I've decided to take the time and build a proper saw vice/ saw chocks.
The through mortises shown in the picture are about 3-5/8" x 2-1/2" (my first ever by hand). With mallet taps, the shoulder line doesn't come together as tight as I'd like. I had planned on simply gluing and clamping, but It will be tough to pull it together with clamps with the tenon sticking out the other end.
I've never draw bored before, but the process seems straightforward. If I do drawbore, what size pins are recommended? How many for this size? Where to place them?
Re: through mortise, drawboring advide
Jack Guzman from Maine
One,1/4" 3/8" from the shoulder
I should explain
I'm not an expert but have done plenty of these. There are no set rules. The dimensions I gave are what I would use in the mentioned instance,based on past experience. Smaller pins will work,so will double pins. Drill the hole in the mortised piece,mark it's location on the tenon and then driil the tenon hole slightly closer to the shoulder. This offset is what causes the "draw" part of the drawbore.
Re: I should explain
Gary B.
Thank you Jack. What wood would be best for the pins?
All I have on hand is Poplar, Southern Yellow Pine (same as the rest of the build), and Cherry.
I wish I had Ash or Oak on hand, but I don't. If necessary, I could go get some. Thanks again! I'll split it and push it through a hole in some steel.
Gary B.
Done. I ended up drilling a hole in an F Clamp to pound it through. I used an old 2x4 (Fir?) for the pins, which was probably a bad choice. The first pin went in fine, but the second one broke, and I had to figure a way to clamp it in a hurry. Glad it was a shop project :-)
I like hickory for pins. I keep a piece of it around for just that reason. Oak also works good but I have used cherry and SYP should work also. Some are better than others but you can use almost anything for a pin. I guess you found out why it would be better to keep a little oak or hickory around. The best woodworking instruction is trial and error. ---Jack
Brian Holcombe
Gary,
The pins should be riven, many people (including myself) make them from splitting stock and finalize them by knocking them through a dowel plate. This makes a rather ugly looking pin but it is round and the grain runs straight.
This is important because the pin once knocked through the joint will be curved, if it runs out at all it will break (as you experienced) rather than doing its job.
Straight (riven) wood tends to flex where wood with runout tends to split where the grain runs out.
William Duffield
In addition to the properties Brian and Jack recommended, I would also suggest air dried. It will be a little less brittle than kiln dried stock. My first choice among commonly available species is hickory and second is ash.
You've heard, I'm sure, of a "square peg in a round hole?" Square pegs have less tendency to work their way out of the joint, especially if used without glue, but there are tradeoffs: They are more likely to split the mortise or the tenon, and therefore require more skill to size, shape and install successfully.
