Warren - Rabbet Plane Question
david weaver
Have you tried Ulmia's double iron rabbet plane? They're dear if bought new, but I found one a couple of years ago for $25, and I always thought that there wouldn't be much to gain with one, but they are a treat.
Curious if you have, because I mentioned this on the UK forum and several people piped up that they love them. the same gains that are there with bench planes are there with the rabbet plane in terms of the penultimate and ultimate shavings, and while the whole plane itself is a bit of a pain to assemble and disassemble, the cap allows it to work far further into the wear cycle.
Re: Warren - Rabbet Plane Question
Warren in Lancaster, PA
It is not a bad idea to have a double iron rabbet plane. Peter Follansbee posted a picture of a double iron rabbet from maybe the 18th century. It had a loose double iron. I had seen a similar one earlier.
Frankly though, we rarely make a rabbet that shows enough that we care about surface quality. We do use rabbet planes a part of complex mouldings, but in that case we generally use near perfect timber and don't need the double iron.
david weaver
I suppose I favor it because near perfect wood for mouldings isn't too common here, at least in the burbs, and the number of people milling wood reasonably here isn't like it is out your way.
The setup that follansbee has as you describe it might be easier to use. The ulmia plane has to have the mouth loosened, slid forward and then the iron coming out isn't that friendly, taken apart and then everything reversed. since the whole setup is wood, it doesn't go back precisely (as in, you might be able to take a few thousandths shavings but then after reset, not be able to do it without fiddling the front sole). Fortunately, it will go for a long time between sharpening sessions if you use something else to hog.
I usually follow a "normal" rabbet plane with it, just as an issue of cleaning up.I wish I could say I had a single piece of 8 foot long clear 8/4 cherry in my shop, but I don't. If I was tasked with making things for other people, I'd have to solve this problem.
