Hollowing plane
Hollowing plane
Hollowing plane
Josko Catipovic
I need to plane a cup into a flat plank for carvel boatbuilding (so the plank will lie flat against bent ribs.) I have a wooden plane that sort of does the job, but has anyone encountered a metal or wooden adjustable version? It would be like a compass plane, except the curve in the sole would be 90 degrees to a compass plane's. I can sort of make it work with a flat-sole plane and a curved blade (like a scrub plane's), but it works much better with a curved plane sole. Any insight appreciated.
I suppose a cooper might use something like this to fair the insides of barrels.
Re: Hollowing plane
Re: Hollowing plane
Don Goodwin
If I understand your question properly, check out the most recent issue of Fine Wood Working (October 2017, No.263). Two articles, one on making a coopering plane (page 24) and one on making a wall cabinet with curves (page 48).
Re: Hollowing plane
Jack Guzman from Maine
build your own
I don't know of any adjustable versions of this but a gutter plane would plow the hollow you want. It is a bit too curved I think though. Another possibility would be to modify a wooden plane to suit your needs. Shape the sole to the curve you want ,then grind the iron to match. I did this with a wooden smoother to create a double hollow for chair seat hollowing.You can also find molding planes with varying curves and widths. This would be the "round " half of a hollow and round set.---Jack
Re: Hollowing plane
Re: Hollowing plane
joe mohnike
Years ago I ran across a plane that someone had modified. It was an old rebate plane. They used screws to put on a wood bottom (sole). They shaped the new bottom to a round. They cut a slot for the blade and fabricated a blade for it. I tried it and the plane did a fair job, could be improved. You could do something similar and have several soles with different profiles. Just a thought.
Re: Hollowing plane
Re: Hollowing plane
Josko Catipovic
Interesting - I built my plane after reading the Oct '97 FWW, which had an article on coopered doors and two articles on custom wooden plane building. I still use my coopered-sole plane, but of course, it has a fixed radius, and I need to either build another one or two with different radii or (I was hoping) find something adjustable. Durn boats just have so many different radii all over the place. :O
Re: Hollowing plane
Re: Hollowing plane
William Duffield
Patternmakers use planes like you describe. They are equipped with a set of blades and matching detachable curved bottom plates in a series of radii.
http://www.ebay.com/itm/VINTAGE-PATTERN-MAKER-PLANE-PLUS-8-BUCK-BROTHER-IRON-BLADES-WOOD-BOTTOMS-/272813914201
f course it is a lot simpler to start with one round plane of the minimum radius and just take several passes until you have matched your radius. The radius is going to vary along the length of the plank anyway, so a single radius blade isn't going to be effective. You do have a set of radius gauges, so you know when you've hit your target curve, don't you?
An alternative to round planes or backing out planes is a set of shaves:
Re: Hollowing plane
Re: Hollowing plane
TM Stock
I never got all that good at backing out, but good enough to clean up with a sharp scraper and a little modified Kunz squirrel tail when hanging the plank...and good enough for 1970's boatyard work, where most wooden boats were 'keep alive for another season' sort of work. My plane is an old split body round that I reshaped to 8" radius and just a bit of lengthwise curve, which lets you work each frame location, then fair up. You might want to try WoodenBoat Forum to get a better idea of how to do this and best bets for planes.
Re: Hollowing plane
Re: Hollowing plane
Garrett Hack, in his plane book, shows two versions of a patternmaker's plane with an iron body and interchangeable wood soles with matching irons. I've been watching, so far without results, for such a thing to appear in my neighborhood.
In the meantime, will regular wood bodied hollowing planes work for your application? They're not hard to find, and you can get different shapes in quite a range of curves.
Re: Hollowing plane
Re: Hollowing plane
William Duffield
Your neighborhood is not in the "Rust Belt," the natural habitat of patternmakers. :D
Re: Hollowing plane
No, alas!
Re: Hollowing plane
Re: Hollowing plane - 'stoup plane'
Josko Catipovic
Apparently what I'm after is called a 'stoup plane' and they all seem to be made with a fixed compassed radius, or as a single wooden body with multiple soles and blades.
Re: Hollowing plane
Jim Matthews
http://info.iyrs.edu/iyrs-school-of-technology-and-trades-rhode-island?utm_campaign=admissions&utm_source=google&utm_medium=cpc&gclid=CJPWjo2pgdYCFVI6gQodrqYHQQ
There's a boatbuilding school in Newport, RI.
Perhaps they can help you.
Re: Hollowing plane
Re: Hollowing plane
TM Stock
John Gardner's 'Building Classic Small Craft: Volume 2' has a well done chapter on planes for boatbuilders, and show general plans and process for making planes suitable for backing out, as well as a razee jack and jointer. The backing out plane is essentially the same as a coffin-sided smoother, but with a laterally curved sole and mount cut for the curve profile of the iron.
Gardner's book is worth having in any boatbuilder's library, and can be found in most library catalogs or from Amazon as a two-volumes-in-one paperback for about $23...look for 'Building Classic Small Craft: Complete Plans and Instructions for 47 Boats'.
Finally - I would register for and spend some time on the WoodenBoat Forum and any other boatbuilding fora you can find. Boatbuilding is it's own unique craft, so worth spending some time there where the domain knowledge is both deeper and broader. Come back to WC and other generalist woodworking sites for some of the stuff that is going to be more frequently discussed here in depth (sharpening, restoring old tools, workbenches for non-boatbuilders, etc.).
